MBruns for President
3.4 Progress
Well my time line is moving up, little and big packages are showing up at the door everyday... Finished a little engine compartment R & R...
And yes, those little green shocks are a product of "while you are in there..." And of course, my custom chip came from Steve...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I can hear her calling: "here engine, here boy..." coming along nicely I see! Did you by chance weigh your old engine sound pad? I was expecting for it to be fairly heavy (after reading some of the posts here, and maybe was on the earlier cars), but mine weighed in at a whopping 4.5 lbs (I think it was)....WooHoo!!!
The appbiz one is lighter - but not by much... This one is definitely thinner - and should make it easier to access the air cleaner. Both plusses...
Jeremy, engine compartment looks great ! That new pad really brightens things up in there. Also anxious to see that bad boy on the road. You are doing good ! Doug
Thanks Doug - wifey is "over the whole car" in pieces in the garage - so updates will hopefully be pretty fast and furious...
Here's a before picture... Actually have the old clutch fork - so weltmeister update on the way I'll try and keep this thread updated as things progress
Schleprock
You still have speed control and A/C? What's wrong with you?
Don't throw away that old fork and shaft. Yours is still in good operable condition. Clean and relube would make that work well for a long time. I'll bet years from now there will be somebody asking if anybody has an original G50 shaft and fork. I'm not saying that's a good thing. Just predicting it'll happen.
Kevin L '86 Carrera "Larry" |
Will program for food
Nice job Jeremy!
Here is a really empty engine compartment... I am way behind you!
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Don't worry, Steve has included a custom "AC" setting on the chip. It basically tries to counteract the horsepower sucking compressor on the 3.4 so its output is close to a non airconditoned 3.2
(Sorry Jeremy)
Schleprock
Joking aside, it has been a brutal summer for the 911 in the NorthEast. The summer's weather has been in the high 80's and low 90's with 80-90% Too hot for my nonairconditioned black interior coupe, at least for mid-day trips.
Bling Bling Baby!
I've never been known for taking the low key road...
The parts look great Jeremy, the only way they would look better is if you had plug holes in the lower valve covers !.......Doug
You gonna use the Club Sport valves or something else?
All six intake valves were worn beyond spec (and in a 57,000 mile engine, go figure) so they were replaced with stock valves - not TRW - I have the name written somewhere - german company I have not heard of...
Doesn't want/need a 3.6L
Ralph |
That's it!
Well, Supertech Head Studs Installed - Fan and Housing and alternator put back together - a BUNCH of things cleaned - life is good (so far anway) Hopefully I'll get my Cylinders and Heads Back and can get it looking more like an engine by tomorrow
![]() Pictures of Supertech Head Studs
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 Last edited by JeremyD; 08-16-2005 at 06:05 AM.. |
Oh - got the welmesiter clutch update installed too - woo woo - Mine hadn't been updated so I have more material on the "ears" of the transmission casting (which makes me a happy camper!)
