Why does engine die when I remove oil cap?
Just recently engine would kill when removing oil cap. The only thing I've done is adjust valves and MSD. Tune up 1500 miles ago
_______ 1981 SC |
I think this is a good thing. It means you have no vacuum leaks. Removing the oil cap creates one.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
UFLYICU
Idle should drop, but it shouldn't die.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
I'm glad there are know vacuum leaks, its a bit of a chore to check oil level though, and don't recall having any leaks in the past because idel would drop noticeably the but never die.
_______ 1981 SC |
sorry for the THE did"nt proof read
Formerly bb80sc
What RPM does your car idle at? Hows your fuel mixture?
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
"cone" in oil filler neck hose, is missing or skewed. (it is called a restrictor in the parts catalog)
poof! gone |
I was under the assuption that the 3.2 had a restrictor not the 3.0. Does anyone have a part number?
part number is in the first link, that bill provided.
poof! gone |
Parts Heaven says that number is the oil tank
The first # is the '81 tank that first used the restrictor, the second #930 107 289 00 is the actual restrictor.
