Moke81's Avatar
Why does engine die when I remove oil cap?
Just recently engine would kill when removing oil cap. The only thing I've done is adjust valves and MSD. Tune up 1500 miles ago
_______
1981 SC
Old 08-08-2005, 07:46 AM
Rick Lee's Avatar
I think this is a good thing. It means you have no vacuum leaks. Removing the oil cap creates one.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 08-08-2005, 07:59 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Idle should drop, but it shouldn't die.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 08-08-2005, 08:03 AM
Moke81's Avatar
I'm glad there are know vacuum leaks, its a bit of a chore to check oil level though, and don't recall having any leaks in the past because idel would drop noticeably the but never die.
_______
1981 SC
Old 08-08-2005, 08:18 AM
Moke81's Avatar
sorry for the THE did"nt proof read
Old 08-08-2005, 08:19 AM
Formerly bb80sc
Vipergrün's Avatar
What RPM does your car idle at? Hows your fuel mixture?
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 08-08-2005, 08:20 AM
vash's Avatar
"cone" in oil filler neck hose, is missing or skewed. (it is called a restrictor in the parts catalog)
poof! gone
Old 08-08-2005, 08:22 AM
Bill Verburg's Avatar
this has been gone over repeatedly
Once
twice
thrice
Bill Verburg
Old 08-08-2005, 08:31 AM
Moke81's Avatar
I was under the assuption that the 3.2 had a restrictor not the 3.0. Does anyone have a part number?
Old 08-08-2005, 10:40 AM
vash's Avatar
part number is in the first link, that bill provided.
poof! gone
Old 08-08-2005, 10:44 AM
Moke81's Avatar
Parts Heaven says that number is the oil tank
Old 08-08-2005, 05:47 PM
The first # is the '81 tank that first used the restrictor, the second #930 107 289 00 is the actual restrictor.
Bill Verburg
Old 08-08-2005, 08:12 PM
