Replacing the targa front bar seal
It appears that the front bar seal on my '79 Targa has shrunk. I assume this is what's happened, as on both sides of the car, the seal doesn't reach far enough down to fully protect from rain etc. There is, in fact, a substantial "hole" where the seal should meet up with the door, but doesn't quite get there. I have priced the seal and am prepared to shell out the cash, but I need to know whether this is a DIY project or not. I prefer to do as much work on this car myself as possible, but I've read some stories on replacing various seals that suggest that it's a real pain in the a$$. Could someone please share with me your experience with this type of maintenance? How much time should I allot for the project? Are there any special tools needed? Can I screw anything up by trying to do this myself? Any advice is welcomed and greatly appreciated. Thanks in advance.
Frank F.
Old 08-08-2005, 08:55 AM
I replaced miine years ago and if I recall it wasn't all that difficult. I have heard that the seals do not match original. Do a search. Something about having to trim the new one down to get it match up with the roof.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 08-08-2005, 09:02 AM
Breeang's Avatar
There is an additional seal that mounts directly on top of the door window that plugs this gap.I have yet to do this job although I have bought all the bits,I shall be just as interested as you in any answers.
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!.
1977 911S 2.7 to spend money on
2006 Tundra for acting grownup
Old 08-08-2005, 09:09 AM
Breeang's Avatar
Red face
Wait a minute-----I was talking about where the Targa top meets the side window. (Ignore last transmission)
Old 08-08-2005, 09:13 AM
Actually, I'm also having a little leakage issue with this area too. Let's see, how to explain this....on both sides of the car, there is a small opening at the top corner where the targa top meets the top of the vent window/windshield area. I have to keep some napkins handy so that I can quickly plug the hole when it starts raining. I've been told to use some foam rubber sealant, but haven't yet looked into it. Beginning to think a coupe would have been a better investment......but this is my first 911, so I guess you live and learn.
Frank
Old 08-08-2005, 09:20 AM
Frank, It sounds like your vent windows are simply lower than the top as they were on lime. I reaised the drivers side vent window. You have to take the rood panel off to access the 3 or 4 bolts but its not difficult to do. Top still leaks but its in the shop for engine rebuild. When I get it back next week that's the first thing I intend to fix.
Old 08-08-2005, 09:48 AM
