Problem with MSD up grade
I just installed an MSD ignition with a blaster coil. I also replaced distributer cap, rotor and plugs. I set the gap as described in Wayne's book. With this up grade, would the timing need to be reset?
My problem is I have rough idle and while driving when I reach 5000 rpm the car will stop accelerating and start to miss badly. When I let off the gas and slow down it will smooth out again. I have changed fuel pump, fuel pump relay and filter in the last 100 miles. One thing I have not done is replace plug wires. This is starting to get expensive. Please HELP.
James 1978 911 SC Targa |
If you have stock spark plug wires with Beru connectors they could be your problem. With the MSD a non solid core wire is needed. Also check your timing. Sounds like you may be too advanced. Of course the timing check is the easiest and quickest. Always the place to start.
Jim
69 911 2.3Ez 85 928S |
You must get the correct wires, you may have already fried one and be running on 5 cyl. and therefore a rough idle. Timing should not need to be reset, but with all the ignition work it would be wise.
68 911L |
check to make sure you do not have the Magnetic pickup wires reversed. I had similar symptoms when I accidentally connected the violet MSD wire to the green distributor wire and the green MSD wire to the shielding around the green distributor wire.
here's the wiring info I used for my 83 with a 6 pin CDI Large red is 12v power and large black is chassis ground. Brown wire to coil neg is 31-1 and connects to MSD thin black wire White wire to coil pos. is A and connects to MSD orange wire Red switched power wire is 15 and connects to MSD thin red Green wire from distributor is 7 and connects to MSD magnetic pick-up green wire Shield wire around distributor green wire is 31D and connects to MSD voilet wire All that leaves is a black wire (with violet stripe?) that connects to the MSD Tach output connector and the MSD white wire. If you have points, you use the white wire and leave the magnetic pick-up wires disconnected.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
Senior Member
JW says the MSD units don't work well with the SC's. Folks who think MSD is the end-all of ignition systems are wrong. Folks who thing Permatune is best, are also wrong. I don't know why anybody would use anything but the Bosch factory unit.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
On my previous 3.0, I had good results using a GM Delco transistorized module in place of the Bosch CD with an HEI coil on carbon core ignition wires with plugs gapped at .060". My current 3.2, I'm still using carbon core wires with the stock DME ignition which is capable of firing my plugs at .060" better than the orignial Beru's could ever do at 0.28". Joe Last edited by stlrj; 08-10-2005 at 11:23 AM.. |
My car runs so great with the Bosch unit, I've seen no reason to change anything. I think Supe may have something there.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
I found the MSD CDI with an MSD coil to work great on my 83 SC. Better low end torque, smoother mid range power up to the red line, and an added 1.5 MPG's consistenly. I am running Magnacore wires but have not regapped my plugs yet.
JLW,
Is the coil you used the epoxy-filled High Vibration coil?
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I used the Hi Vibration Blaster coil that our host sells to go with the MSD.
I used magnacore and a non rev limiting rotor. The rev limiting rotor can also be bypassed with a soldered pin or jump wire.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Rex
1975 911s 1997 Saab 900s |
To add to the info in RoninLb's link, there is a tall rotor and a short rotor used in VW Bug distributors. You want the tall one. If in doubt, bring your rev-limiting rotor with you and match the height. They fit the shaft perfectly and don't wobble.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Modern electronics... actually, except for the multi-sp[ark feature, I don't think we know that the circuit design is improved. But, certainly, the components will be newer than a used Bosch unit.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
my SC will rev to the heavens. MSD, hi vibe coil, and beru wires. PO installed it tho.
poof! gone |
I tried plugging the #'s into the pelican part search at the top of this page and it wouldn't come up.
The admonition not to use solid wires is strictly to minimize RFI/EMI interference with other systems in the car, and has nothing to do with any potential damage or running issues with the MSD! Many people have used stock Beru wires, or other solid-core wires with MSD ... and had no problems.
The biggest issue with MSD causing misses or other drivability problems is pinholes, cracked, and damaged ignition wires that can cause arcing and corona-effect ... visible at night or in a dark garage with the engine running! Every arc or glow you see is energy that isn't getting to the spark plug!
Thread Tools | |
Rate This Thread | |
