abit off center
cgarr's Avatar
LM-1 first run
This thing is slicker than snot, had a few bugs with rpm jumping around but with some help from SW got it nailed, This shows a run with my 86 3.2 from about 1200 rpm to redline in third gear WOT to the floor, mashed,,,,, now you all will have to tell me what it means?? Im only recording AFM, RPM and WOT
Craig
______________________
Craig
G2Performance
Old 08-12-2005, 11:42 AM
I think your RPM range is set up wrong - it should read 0... 7000 or so? Your A/F is in the 13-14 range so I think its good for a NA engine. In an ideal case, at cruise, you want to see ~14.7 AF
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 08-12-2005, 12:51 PM
abit off center
cgarr's Avatar
Yea, I dont know if you can overlay both the rpm and afr, you can switch from one to the other, maybe someone knows how to display both?? I know this thing is very sensitive, you fart in the same room and it will show up!!
Craig
Craig
G2Performance
Old 08-12-2005, 01:32 PM
Craig,
Select the acceleration run ONLY with the selection tool. Then open an X-Y-Plot and select AFR as Y axis and RPM as X axis. Check the --- radio on the bottom of the X-Y plot. With Alt-Print Screen with the X-Y Plot as front window you can put it in the clipboard and paste it into Paint. You can then post that picture without printout and scan.
Regards,
Klaus
Old 08-15-2005, 11:58 AM
