alternator light question
Just finished replacing the alternator in my 78SC , due to bearings gone bad. All connections on back hooked up exactly as the old one...belt tight...good to go. Start it up and the red dash alternator light stays on??? Never did this before. Should I have replaced the external voltage regulator at the same time?
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2005, 03:59 PM
Though I am probably the least experienced person on this board when it comes to maintenance issues (I'm trying to learn though), I had similar situation with my alt light and was told that it is likely related to the voltage regulator. Not sure if it has to be completely replaced, but it sounds like it's probably the source of the problem.
Frank
Old 08-12-2005, 04:06 PM
dweymer's Avatar
Did you fully charge the battery before starting the car with the new alt?
Donnie
Currently Porsche-less.....
Old 08-12-2005, 04:08 PM
No, I didn't charge it..but it is fairly new and I haven't had any problems with it. Started very easily after installing the new alternator.
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2005, 04:13 PM
