vizail's Avatar
Advise on removing F- Injectors
When removing fuel Injector(CIS-Jetronics) is there some kind of lubricant that can be use to prevent damage to the sleeve?
Vic
Old 08-12-2005, 12:52 PM
KNS KNS is offline
The sleeve wll either come out easily or it will not. When I pulled my injectors, three come out with the sleeve and the other three needed to have the little 'nibs' on the intake runners ground off. I bought six new ones with new O rings, etc. I don't know of way to lubricate them, the little nibs that are staked into the aluminum are going to hold 'em in place no matter what.
Kurt
Old 08-12-2005, 02:53 PM
vizail's Avatar
KNS
Thank's for the reply
I'm talking about the Injectors only not the sleeve . I don't need to take the sleeve's out.
I just want to make sure that the sleeve stay in place and only the Injector comes out. I just wonder if some of you guys have used a lubricant to make the Injector extraction easy.
I just want to take the Injectors out for cleaning and calibration and or replacement. Of course I know that when one take an Injector out you have to replace the Injector
O-ring
Vic
Old 08-12-2005, 04:03 PM
