Progress pictures - '68 rust work
I wanted to share some pictures - my '68 911T is back home after the first step in a total restoration -- two months of major structural rust work to replace the floor, rockers, and nose!
A discussion of the work and a full set of pictures is at Karosserie
Licensed User
Nice work Mike! Youre a better man than me. I would have run away screaming from that
Not Quite Banned
That was a lot of rust - good work.
Thomas Owen 1972 911T 1972 911S |
Brave man. Nice work.
Jay '08 E350 Wagon '74 914 gone '72 T gone |
DP935 member
Good job. Thats alot of work and glad another one is saved.
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
Good job Mike....
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
Recreational User
Hey Mike!
Thanks for the inspiration! I'm just about to start on replacing the floor pans on my '66 912 and found the photos detailing the process very helpful. One thing I did notice in the following picture was how the original sheetmetal under the center tunnel was left intact on your car. http://ladwigindustries.com/mike/68-911-1/generated/52.JPG I was planning on removing the sheetmetal under my tunnel but now think why bother. The rust was limited to where water pooled under the floormats and the sheetmetal on the tunnel floor is very solid and would provide additional support if left intact. I have also noticed the steel in my replacement pans is 18-gauge and the original stuff was about 25% thicker. Any reason this would not be a good idea? Darryl D. Last edited by DarrylD; 08-13-2005 at 10:12 AM.. |
Gon fix it with me hammer
wow
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Longhoods Unite!
looks like how my car started out when i got it, you'll be VERY happy with the hard work put into it when its done
1970 911T -- Neglected, oil burning problem, batman smoke 1974 914 2.0 Weber'd -- new project!! **My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
Thanks all. Brave? No - I have a lot of motivation to bring this particular car back - otherwise it's not a good choice!
Darryl: The only floor seam in the center that was swollen was in the very back by the tunnel, so we figured we'd replace all the way across the back half and then look up the tunnel to see what it looked like up front. Once cut open, you could see it was perfectly clean - no reason to disturb the original work. The worst rust (you can see it on the "before" pictures elsewhere in my web site) was in the 12 inches closest to the outer rockers so this wasn't unexpected. The floor pan, tunnel, and rockers do a lot to set the geometry of the car, so the more you can leave alone the easier it will be to get good door gaps. |
Recreational User
Hey Mike!
That sounds like a great idea. I was studying the cross-section of the tunnel on my donor front clip and noticed the guide tubes for the throttle rod are welded to the floorpan sheetmetal. ![]() I'd like to minimize critical alignment stuff like this that there is only one shot to get perfect. Seems like having a double thickness of sheetmetal on the bottom side of the tunnel is a small price to pay for knowing the control alignment hasn't been affected. I don't delude myself into thinking two layers of steel on the bottom of the tunnel detracts from the value of the car when I'm finished in any way. It will never be factory original no matter how perfect of a welding job I do. I'm more interested in it looking great from the bottom side when there's a nice thick coat of Wurth Stone Guard covering the whole thing and could care less about what it looks like when you pull up the carpets and sound deadening material. Darryl D. |
19 years and 17k posts...
Great work! You're an inspiration to me!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
"two layers of steel on the bottom of the tunnel"
I don't know if that would be a problem - it might form a pocket for rust to return some day. On mine, we removed the floor under the tunnel in the back, and left it in the front -- but there we cut the front section in pieces so there was no overlap. |
Recreational User
Yeah Mike, I thought about the double layer cavity leaving the tunnel floor in would create. I think the rust hiding in other areas will progress faster than new rust will form in that area. I try to be a realist when it comes to rust knowing there is no way to turn back the clock on these old cars and there's some more of it hiding somewhere that will eventually bubble through. Until then I'll just drive the hell out of this old 912 and be too old to care when it shows up!
Darryl D. |
