K9Torro's Avatar
Question Need a little engine room help
Hi
Can anyone take a look at the pic below, and tell me what hose I am missing that connects where the red arrow is drawn to that large round opening coming off the fan shroud, and where it is supposed to go ?
Thanks in advance,
Todd
Old 08-14-2005, 02:34 PM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Through the engine tin to the heater duct on the heat exchanger. It is your heat.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 08-14-2005, 02:37 PM
Gon fix it with me hammer
svandamme's Avatar
hot air blower and tubing
Stijn Vandamme
BIMDIESELBMW116D2019
Old 08-14-2005, 02:38 PM
K9Torro's Avatar
Hi
Thanks for the help, my car does not have heat, the PO took put on a aftermarket exhaust and it uses the open tube design headers, any idea on what else I could use this for?
Todd
Old 08-14-2005, 02:43 PM
svandamme's Avatar
just make sure it's plugged up or you loose cooling
the right side has a blocking plate , but the left side doesn't
unless it's plugged inside the socket , the fan will blow through that hole , instead off blowing over your heads and cyllinders
Stijn Vandamme
Old 08-14-2005, 02:46 PM
svandamme's Avatar
PP sells block off plates
you have the right one , migt get the left one , not expensive
made out of plastic , see the one on my engine
all you need to do is unbolt the old hot air socket
drill a hole in the new plastic one
and bolt it in place
Stijn Vandamme
Old 08-14-2005, 02:51 PM
