Somatic Negative Optimist
Gunter's Avatar
Question Volume-testing for CR question
How exactly is it done?
Can someone post details for equipment, formula. etc?
Thanx
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-15-2005, 06:17 PM
MBruns for President
JeremyD's Avatar
Re: Volume-testing for CR question
Thanx
Try here
Old 08-15-2005, 06:32 PM
JeremyD's Avatar
Here's a good resource too
http://www.rbracing-rsr.com/compstaticcalc.html
Old 08-15-2005, 07:04 PM
abit off center
cgarr's Avatar
This one too, just enter 2 then your in mm, if your cc'ing the cumpustion changer with the engine togeather then you can leave out all the other measurements, all you need is the bore, stroke and what your chamber cc'd at http://www.csgnetwork.com/compcalc.html
Craig
______________________
Craig
G2Performance
Old 08-15-2005, 07:13 PM
randywebb's Avatar
I posted on your other thread ...
BTW - a formula can be used if you have flat top pistons.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-15-2005, 08:54 PM
Jeff Alton's Avatar
Lets see some pics of your tools for measuring.....
Jeff
www.turn3autosport.com
Old 08-17-2005, 09:02 AM
abit off center
cgarr's Avatar
When I did my 912 engine, rolled it on the stand so the plug hole was up, set it at tdc, filled the combustion chanber with water to the plug hole which was 51cc The bore is 86mm stroke is 74mm that gave me a cr of 9.4 to 1 very easy and accurate..
Craig
G2Performance
Old 08-17-2005, 10:11 AM
Gunter's Avatar
Thanks Craig: A burette is necessary in any case. Water is not my favorite because of rust concerns; but one could use a thin oil.
Interesting; TDC, fill with.........thru plug hole, ??cc's, bore & stroke.
Sounds easy enough. I am a long way from doing it but it's good to know how CR is confirmed.
Old 08-17-2005, 05:40 PM
randywebb's Avatar
use ATF
Old 08-17-2005, 05:55 PM
Jim Williams's Avatar
Here's another, if you want to wade though it... I didn't post the graphics, but they're in the Oct 97 Porsche Panorama magazine if you can find a copy. Or if there's any interest, I think I can find the graphics on my computer and post them.
http://members.rennlist.com/jimwms/Tech/comp_ratio.html
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 08-17-2005, 06:11 PM
JeremyD's Avatar
Bruce anderson has a pretty good description with pictures too.
Old 08-17-2005, 06:40 PM
Irrationally exuberant
ChrisBennet's Avatar
It's not the method I use but I like it.
The advantages I see are that you don't need expensive Jo blocks (Bruce Anderson's method) and you don't need to measure deck height (my method) directly.
Disadvantages would be the amount of fluid necessary (multiple fillings of the burette) and the possibility of fluid getting into the motor.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-17-2005, 07:22 PM
Chris,
I came up with this trying to find a little easier to understand method. Deck height is handy to know for other reasons, but I couldn't see where it was necessary for C/R.
The volume around the piston dome can be determined with the piston and cylinder out on the workbench before they are installed on the engine, so you don't have to worry about fluids in the engine. It's also easier to level the p/c when they're on the workbench. This makes the cc'ing easier and more accurate. The top of the piston dome is adjusted to be level with the top edge of the cylinder, resting in contact with the plexiglass cover, so the only fluid used is that actually around the piston dome.
Only two burette fillings are necessary. One complete fill for the combustion chamber volume (under 100 cc) and one for the volume around the piston dome (well under 100 cc).
The only measurement needed on the engine is distance from the top of the cylinder down to the top of the piston dome, with the piston at bottom dead center.
Jim
Old 08-18-2005, 08:15 AM
Aha! Even better! I misread your article. I see now that you only measure the depth down to the piston when the engine is assembled, no fluid involved. I like it so much I think I'll try it on the next motor I do.
Sometimes I'm jealous of you guys with the big brains...
-Chris
Old 08-18-2005, 08:34 AM
