Radio security code
I have a real nice Blaupunkt without a security code. Am I plum out of luck? There is a four digit number on a sticky tag on the back. But, aren't the codes usually multiple letters and numbers?
Jack |
I do not think so , according to other factory radios I has the security digit ARE ONLY numbers cause the radios has only numbers (for the stations) in there not letters. Also the security code comes in a separate tag with the operations manual not in the back of the radio cause anybody could use it after steal it if the put the security code there.
JLGS |
Jose Luis is correct. I bought a used Blaupunkt that did not have the code. I contacted them , gave them the serial number of the unit and got the code. One other unit I got had a code but it was diaabled somehow. Put power to the unit, if the digital window reads CODE, then enter the 4 numbers you have, if that doesn't work, contact Blaupunkt and give them the serial number. I didn't pay anything for the info but it took a few calls to get it.
Tony G 2000 Boxster S |
Thanks a lot Tony. I appreciate your help and will follow your suggestions.
Jack |
