Honey Badger
SC has starting issues when semi hot (ignition related)
I went to the gun store today and when I came out (30-45 min) no start. It just kept turning over. I checked for spark and got none so I started messing with the CDI unit (pertronix). I took to connector off and heard some clicking and put it back on. When I went to start after that it started instantly. Went to get a haircut (30-45 min), same thing happened. Took the connector off put it back on and instant start. Went to gas station (2 min) no problem starting. Came home sat for a while (1 hr) and went to try and start, nope.
Any ideas?
1978 911SC 1953 Piper PA-18A USAF EOmfD |
Honey Badger
Sorry, I meant to sy Prema-tune not Pertronix.
Oh, also it runs fine after it is started.
1978 911SC 1953 Piper PA-18A USAF EOmfD Last edited by theFONZ; 08-19-2005 at 06:30 PM.. |
It's your Permajunk ignition. I had the EXACT same problem. Right now I'm running on a spare Permatune CDI but am promptly getting a rebuilt Bosch unit soon. Do a search on "Permatune". You will see a lot of horror stories. Best just to get a rebuilt Bosch unit. There's something faulty in these Permatunes that causes them to die so soon (probably heat related).
Matt '76 Porsche 911 with '78 3.0 SC engine '71 VW Bus '14 VW Passat (toddler hauler & wife approved ride) '03 Subaru Baja original yellow & silver |
Honey Badger
Thats what I suspected.
I'll probably end up doing the same as you, running another Permatune until I can find something else.
D idn't E arn I t
Blame the Permatune. I had a brand new one installed by a shop. Did the exact same thing about 3k miles and less than a year after it was installed. Once it started had to wait a few hours for it to cool off. Got worse and worse until the point it just up and dies while it's running.
Toss that thing in favor for a Bosch CDI and new coil. rjp
AOC/Hogg 2028 |
FYI, the rebuilt Bosch units are like $400. If you buy them new, they are more like $1300, so a rebuilt one won't break your wallet as much.
D idn't E arn I t
rjp
AOC/Hogg 2028 |
Yes, I had 3 experiences when my Permatune quit on me while on the road. Fortunatley I wasn't going too fast and I was mainly on a 2 lane road. Then there were times when the car wouldn't even start after being parked...
theFONZ, I highly reccommend just getting the Bosch unit. You could buy a backup Permatune for a couple of buck if the Bosch quits on you, but what I am doing, even with the "spare" Permatune is risky... get a Bosch ASAP.
Honey Badger
Where can I find a rebuild Bosch? I tried our host and they are NLA.
In the shop at Pelican
Had the same problem using a Permatune. Got an MSD, and havent had any problems for two years
Honey Badger
What all do I need to get to convert to MSD?
theFONZ, I Pm'd you.
Do a search for MSD. Here is a thread I started when I thought about getting an MSD ignition. Thinking of going MSD
