I'm not here.
Engine Stand Adapter Ring How TF?
OK, sorry for being so ignorant...How does it work? Where do I find 16 inch 3/8 inch screws? What part of the engine does attach to?
Pics PleasE!!!! Thanks! K.
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?) Last edited by K. Roman; 08-25-2005 at 11:58 PM.. |
![]() maybe a bit dark, but here you can see how it is attached.. |
a lighter version, it might help:
'89 3.2/3.6 coupe |
Irrationally exuberant
Pictured is a "yoke" The engine stand adapter doesn't have the arms of the yoke, just the half ring that bolts to the motor.
I would assume that you use 3/8" threaded rod cut to length with nuts to mount the ring to the engine stand. -Chris EDIT: I can see now that when you said you needed 16inch long screws you must have meant 6 inch. No need for threaded rod if that is the case.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 08-26-2005 at 06:26 AM.. |
Here are some (poor) pictures of how I've attached mine.
The flat black spacers are black pipe I cut to length. The shiny black part is the yoke/adapter that came with the engine stand - four arms that adjust to mate up with bolts & bolt holes, in this case, on the adapter ring. |
MBruns for President
I have a few
If you are going to use the Mainly by design one - I'd recommend spacing out just a little futher than a regular engine stand adapter goes - otherwise it's a real pain to get clutch, flywheel etc.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
get the bolts from Home Depot/Lowes etc.
I'm not here.
[QUOTE]Originally posted by JeremyD
[B] If you are going to use the Mainly by design one... I am using the Mainly one and that's where the literature said to use 16 inch bolts. Could that be right? Home Depot only had 10 inch, which already look too long!
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?) |
I have 4" bolts - if I was doing it again I would space em out to at least 6 - pref 8"
You really have to measure the motor mount you are sticking them on - measure almost the other side of the carrier (from Mainly) then add the thickness of the motor mount (the yellow on mine) then add the spacer - just make sure the spacers are strong. Then you get a total for the size bolts.
I'm not here.
Danke, Jeremy.
I took a better picture today I;ll post later
Here you go -
I made the whole thing, spacers are 1" dia solid bar[which I found] drilled and tapped both ends.--plenty of clutch room.
room
Nice Bob - is your garage tiled?
Jeremy,unfortunatey the answer to your question is ,-No.
I dont have a garage ,BUT---the entrance hall of the house is tiled with slate!-----As I'm an old ,hermit batchelor, no problems. Bob
sweet!
I'm not here.
Thanks for all the support everyone, I'll be tackling this tomorrow.
Peace!
Somatic Negative Optimist
Question: The adapter ring is fastened to the two bolts protruding from the left case halve, and then four bolts from the engine stand attach to the adapter ring.
So, the entire weight of the engine hangs on two bolts from the left halve of the case? 3-400 lbs on two bolts?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
yep just like the porsche factory stand...
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
