-   -   How many 911 3.6 conversions out there ? (http://forums.pelicanparts.com/porsche-911-technical-forum/238501-how-many-911-3-6-conversions-out-there.html)
chucksmith 07-23-2025 11:45 AM
really well done
Ryan_Cunningham 07-23-2025 01:29 PM
ECU Doctors has them and recommended Bosch part 0 261 204 376 with Driveblock removed. My research shows it’s for a Tiptronic 3.6. They said it should be an issue because the ECU can sense if it’s a Tip and a Tip has its own ECU.
Anyone know for sure if it’ll work ok with my 915? They said if there are any issues to send it back for up to five years and they’ll make whatever modifications that are necessary.
Bill Verburg 07-23-2025 03:02 PM
Originally Posted by arrivederci (Post 12500611)
On the subject of engine mounts, notice that the one in Bill's picture is reinforced at the ends. This is a great idea...those things twist quite a bit.
For transmission durability, I guess it depends how you treat it. I too heard people cautioning me about the 915 but I haven't had an issue nor do I know anyone with a 3.6L that has grenaded their 915. I did go with an '84 euro 915 (not my stock magnesium cased one) and I didn't add an LSD hoping to stress the transmission a little less, maybe having a little wheelspin here or there on one wheel. 911s get such great traction anyhow and I don't track this car, so the lack of LSD is hardly noticeable.
There is a lot of torque going thru the cwp in the lower gears, w/ a 3.8 RS at wot in 1-3 I could make the trans weep
The original mg. /44 was better in this respect as it came stock w/ a steel girdle stabilizing the si/o shafts, I also went w/ a /67 for the trans cooling feature but recomens adding a steel girdle here too.
Bill Verburg 07-23-2025 03:17 PM
There are some minor differences between the tip and manual but a tip ECU will work
on a 55 pin DME I think that it is pin 44 that activates tip coding
Ryan_Cunningham 07-23-2025 05:50 PM
Awesome. Thanks Bill. It’s an 88 pin but I’m just going to put you on speed dial until my swap is done.
If you ever find yourself in San Diego, you bar tab is on me.
jmz 07-23-2025 07:55 PM
Nice build @plexiform
plexiform 07-24-2025 02:38 AM
Originally Posted by chucksmith (Post 12502589)
really well done
Thank you both! Drives amazing but now I'm thinking it might be time to see what a modern Porsche race car is like. But sadly prices of modern GT3s are so insane that may never happen.
Bill Verburg 07-24-2025 08:46 AM
here are the connector pin outs
http://forums.pelicanparts.com/uploa...1753371804.gif
trans is still #42
I think that you need #56 & 82
the tip has a different way to control idle from the manual, I think I recall a TPS and stepping motor on the throttle
flyn-hawn 07-24-2025 11:21 AM
http://forums.pelicanparts.com/uploa...1753381059.jpg
jmz 07-24-2025 01:19 PM
Originally Posted by flyn-hawn (Post 12503206)
Very clean
jmz 07-24-2025 01:29 PM
Getting closer… soon to be IROC tribute. Hope to be running next week after ECU comes back from specialized ECU. Then off to paint, wife got to choose one of the IROC colors, she chose Magenta, will see if I can commit to it soon enough. 1982 chassis with 1989 930 turbo G50 torsion tube and trailing arms grafted in.
http://forums.pelicanparts.com/uploa...1753388488.jpg
http://forums.pelicanparts.com/uploa...1753388514.jpg
http://forums.pelicanparts.com/uploa...1753388587.jpg
http://forums.pelicanparts.com/uploa...1753388652.jpg
http://forums.pelicanparts.com/uploa...1753388699.jpg
http://forums.pelicanparts.com/uploa...1753388730.jpg
http://forums.pelicanparts.com/uploa...1753388799.jpg
jmz 07-24-2025 01:57 PM
Kind of looks like a short hood ST right now but the plan is RSR IROC tribute
http://forums.pelicanparts.com/uploa...1753390499.jpg
http://forums.pelicanparts.com/uploa...1753390572.png
jm58 07-28-2025 08:31 AM
http://forums.pelicanparts.com/uploa...1753716311.jpg
This one has a 3,6 conversion included the 964 gear box and RS92 brakes.
Ryan_Cunningham 08-15-2025 12:50 PM
Originally Posted by Bill Verburg (Post 12500618)
The 993 console, crossbar and modified tin work but force the rear of the engine down over 1 1/4" due to the height of the tin
the 3.2 parts w/ Sheriden f/g tin replacement fits like a glove and returns the engine to it's usual position
That exhaust looks exactly like the one I bought from Fabspeed, and I do mean exactly. If so it's great, best I've ever heard including the ones I've used on my 993.
Only nit is that the tips are a little weal, appearance wise
As is typical, it looks like you were probably right. Unless we can find a way to move the exhaust higher I think I'm going to have significant ground clearance issues. I'm not so concerned about the heat exchangers, but the I'm fearful the exhaust will hit on any speed bump or leaving my steep driveway.
http://forums.pelicanparts.com/uploa...1755287346.JPG
And there is absolutely zero room up top.
AlBackus36 08-15-2025 04:13 PM
Congrats man! It's in there. Mine is tight like that too. Zero clearance on the vram to go higher.
Your fan scavenge thing is cool looking. Haven't seen that flavor yet. I heavily modified the rennline CF tube on mine but it leaks at the bottom where the exhaust side and it meet at the tin opening.
Bill Verburg 08-15-2025 05:06 PM
It's far easier to make room above than to fab a custom exhaust which fits up higher.
Is that the new version of Fabspeed on yours?
If so let us know how it sounds, i love my 3yr old console version.
Ryan_Cunningham 08-15-2025 05:07 PM
Haha, thanks. It’s taken WAY longer than anticipated.
Any issue with your exhaust bottoming out on speed bumps? Thinking about raising the rear 10-15mm and trying to rotate the exhaust to get a bit more clearance before I just pull it all out and buy a new tin.
I want to start this thing!
Ryan_Cunningham 08-15-2025 05:09 PM
Yes, you’re right. I know that is what PMS does.
It is. I’ll post a video once it’s running.
Bill Verburg 08-15-2025 05:12 PM
I had to mod the heating connection where it went through the tin/cf, I used some silicon tube from a turbo intake. To join the upper and lower sections On this one I used the oe RS plastic tube.
froggert 08-18-2025 12:13 PM
This is what my car looks like. It usually only scrapes on steep driveway transitions and the largest speed bumps.http://forums.pelicanparts.com/uploa...1755544399.jpg
