-   -   How many 911 3.6 conversions out there ? (http://forums.pelicanparts.com/porsche-911-technical-forum/238501-how-many-911-3-6-conversions-out-there.html)
mac9 09-11-2005 11:45 AM
This is a great thread. One question naturally comes to mind: How much would you guys say that a 3.6 conversion typically runs? Say for a 94 motor. Do you think that it would be worth it to buy a ready motor from a place like Instant-G?
drums 09-11-2005 11:56 AM
My experience was that taking my 3.2, having a complete rebuild, taking it to 3.4 with new pistons and sleeves, cams, head work, extrude
honed intakes, bored throttle body, clutch, etc., etc. was going to cost about $14,000. This is not too far away from doing a conversion. It will cost a few thou more but the gains in H.P. [and still being legal] are flat
friggin' AWESOME! Do a 3.6 conversion. Save a little longer, if you have to.
Good luck!
Drums
Joeaksa 09-11-2005 12:35 PM
With the 3.6 engine you will be getting a newer style and model of fuel injection system, and that helps. You also will get more hp and torque.
Downsides are that you will lose the engine mounted oil cooler, and that will mean that you need to add one somewhere on the car, which is usually done on the nose but have seen additional ones stuck in the opposite front fender.
Its 6 one way and half a dozen the other. Personally I would rather have a engine build by the little elves in Germany than one put together here. Do a search on 3.6 conversions and you will find that Timmins is not the only one doing them. Some of us prefer to have others do the work if you know what I mean. You do not say where you live on your profile and if its not anywhere near Rhode Island, where ST lives, then I would strongly recommend that you look into other alternatives.
All in all it really provides a kick in the rear in the car.
JoeA
stv951 09-11-2005 01:16 PM
Why do you lose the engine mounted cooler ??? Does not fit ?
Who are "the little elves in Germany "???
Lukesportsman 09-11-2005 03:47 PM
3.6 Doesn't have one.
Elves = Porsche assembly workers
Joeaksa 09-11-2005 08:19 PM
You lose the engine oil cooler to place a mounting pad for a power steering pump on the newer cars. As we do not have power steering, we put a cover over it.
The little elves are the ones who work for the factory and live, eat and sleep 911 engines.
JoeA
blue82coupe 09-12-2005 03:16 AM
Here's mine.http://forums.pelicanparts.com/uploa...1126523663.jpg
Joe Bob 09-12-2005 05:10 AM
JoeA
Power steering is fer pansies.....:rolleyes:
911teo 09-12-2005 05:16 AM
Ok I'll play
here is mine
http://forums.pelicanparts.com/uploa...1126530709.jpg
http://forums.pelicanparts.com/uploa...1126530729.jpg
http://forums.pelicanparts.com/uploa...1126530743.jpg
It started as a stock 1988 Carrera and this is what has been upgraded.
Engine and drivetrain
-1997 3.6 Varioram
-Euro brain and harness
-RSR clutch upgrade
-lightweight flywheel
-Guard Transmission LSD
-72 ROW setrab oil cooler
-Instant-G header and muffler
Suspensions
-21-31 hollow torsion bars
-Bilstein sport shocks
-Elephant Racing triangulated strut bar
-Elephant Racing camber plates
-Elephant racing rear monoballs
-The Racers Group adj front and rear sway bars
Wheels and brakes
-9.5x17 Lindsey Racing front wheels
-11x17 Lindsey racing rear wheels
-275/40-17 BFG front tires
-315/35-17 BFG rear tires
-Brembo GTP brakes
-23mm Master cylinder
Interior
-2 Recaro Pole Position SPG leather
-Schroth 6-point harness
-ISAAC head & neck restrain
-BK harness truss
-BK seat belt mounts
-Appbiz RSA door panels leather
-UltraLap timer
-Momo Race steering wheel
-Rennline alluminium floorboards
-Rennline pedal set
Exterior
-TRE 934 front bumper
-TRE IROC rear bumper
-Vitaloni California mirrors
-930 front fenders
-RSR steel rear flares
-Hawker battery
stv951 09-12-2005 10:04 AM
wooowwwww 911teo thats a great car !!!
911teo 09-12-2005 10:37 AM
some more pics
http://forums.pelicanparts.com/uploa...1126549625.jpg
http://forums.pelicanparts.com/uploa...1126549639.jpg
http://forums.pelicanparts.com/uploa...1126549773.jpg
Thanks for the comments... It took a long time to get here...
Basically the whole car was upgraded. So between coordinating the parts, the bodyshop and the mechanical upgrades 6 months went by.
This is my daily driver so I decided against installing a roll cage.
I am still trying to fix some little annoying problems but it should all be wrapped up by the end of this week.
If I had to do it again I'd call Porsche Doc (or TRE motorsport or Rennsport systems) and commission a car to my specs...
Is it worth it? To me yes, I love the idea of having a unique car that was put together for you. This is also the reason I went for the 934 front bumper/splitter... less common. I must say that I am having second thoughts... even though it is growing on me.
If you have any other questions fire away... I'll be happy to help you any way I can....
KobaltBlau 09-12-2005 02:05 PM
especially on a rear engined car. I don't get it!
CBRacerX 09-12-2005 07:34 PM
Lets add to the fun...
http://forums.pelicanparts.com/uploa...1102355726.jpg
Initial Conversion Thread
http://forums.pelicanparts.com/porsche-911-technical-forum/169698-3-6-964-3-6-964-w-varioram-intake.html
Exhaust Thread
http://forums.pelicanparts.com/showthread.php?s=&threadid=195581&highlight=varior am+964
Breakdown:
1990 964 Long Block with '98 993 Varioram Intake and Euro 993 DME/Harness
3.8 RSR Flywheel, Clutch, Pressure Plate
993 Heater Boxes and Crab Muffler (w/heat!)
New Wheel Bearings F/R, Elephant Racing Monoballs and Bronze/Poly Spring Plates on rear
New Axles and CV's
SRP Bump Steer
Hollow Torsion Bars
Reinforce Rear Swaybar Mounts with SRP Reinforcement Kit
TRG Front/Rear Swaybars
Shocks - SRP Revalved Bilsteins
RUF Oil Cooler and Spoiler
RUF Wheel
RUF Tachometer
RUF Floor Mats (easiest part of the job!)
BRD Center Armrest (love it!)
New Windshield and C2 Rubber
Rear Mudflaps - I love these!
993 Aero Mirrors
Euro H4's
993 TT Brakes F/R
Align, Ride Height, Corner Balance (subbed out)
Drive!
WydRyd 09-13-2005 04:26 AM
Cool thread ;)
If I ever did up another HP-Junky Hybrid, I'd start with a 3.6 transplant, slip in some custom forged JE Turbo Pistons and twin turbo the sucker using a pair of Garrett Ball Bearing units ;)
No harm in dreaming :D
911teo 09-13-2005 04:30 AM
I thought about turbocharging the 3.6 varioram... It is easier and cheaper to get a 993TT engine... they go for around 22-25k. 408hp at the flywheel stock. Easy 650hp.... on a 2,400lbs 911... :)
stv951 09-13-2005 09:10 PM
Anyone knows of an early 911 with a 993 TT engine ? I guess that wold require a G50 conversion, as I doubt a 915 would be strond enough. This would be close to CTR teritory.
Jack Olsen 09-13-2005 09:27 PM
Henry Watts has a 1972 with a built 993TT motor in it. It is very fast. I assume he's got a G50, but I'm not sure.
Garrett 09-13-2005 09:55 PM
It's interesting how many Targa's end up with 3.6's!!!
Neat cars, guys! :)
WydRyd 09-14-2005 01:40 AM
You can run 0.45bar boost (twin turbos) on a stock 993 Varioram engine for 410HP at the flywheel. It's all in the reprogramming of the engine management system and efficient intercooling ;)
ted 09-14-2005 07:07 AM
Henry's super fast 911 also has the 993 rear suspension as well.
A G50 with big power would be best but the cost to build a G50 race trans is much greater than the 915. Then again if you are into it that deep (G50/993TT conversion) some gears for a G50 should be no big deal. :)
911teo 09-14-2005 07:42 AM
ted
how do the 993 suspension geometry and the 935 set up differ? Why (if it is) is the 993 so much better?
Jack Olsen 09-14-2005 09:01 AM
The 993 rear end is a whole different animal. It's a modern, multi-link design as opposed to the old semi trailing arm setup. Once it's stiffened up, there's no beating it. Of course, it's very expensive to put into an earlier car.
911teo 09-14-2005 09:13 AM
and how many seconds a lap is it worth?
Jack Olsen 09-14-2005 09:48 AM
That depends on the rest of the car. In my opinion, it fits into the 'money is no object' category of upgrades, sort of like a G50 transaxle with custom gears. The 993 rear end is not good value, in terms of bang for buck. But if the object is to build a winning race car, at any cost, it's a no-brainer.
Kevin Stewart 09-14-2005 09:56 AM
Jack is there any place to find what the specs are for heigth of the sub frame, i am thinking about cutting my car up, and seeing how we are gonna put a cage in it we might as well attach the sub to the cage, of course this is kinds in the hmmm stage, Kevin
rcollins2867 09-14-2005 11:15 AM
3.6 Conversion, what exhaust used
I am in the process of swapping motors on my 1985 Cab 911, with a 1997 Varioram, and have been having problems figuring out what exhaust system to use, I was told that the headers from the 993 motors are the best available and i want to use them, and find an exhaust muffler system that will allow usage of the 993 headers and catalytic converters, however with different mufflers since I was told that the 993 muffler set up would not work......What did all of the people here do on exhaust, I have a C4 turbo body upgrade on a 1985 chassis.....Any help with companies that have a muffler set up....I tried B&B to no avail...
Rob Collins
510 472-9091 Cell
911teo 09-14-2005 11:18 AM
I would start here
http://forums.pelicanparts.com/porsche-911-technical-forum/237499-3-6-exhaust-solution-la-triad.html
CBRacerX 09-14-2005 11:47 AM
Rob,
You might also look here
http://forums.pelicanparts.com/porsche-911-technical-forum/195581-i-got-crabs-weekend.html
randywebb 09-14-2005 03:46 PM
re the rear 993 susp. in an early car:
and there was an article in Excl. some years ago - I only know of this being done in 2 cars -- of course, I don't live in California -- could be thousands of 'em down there...
Jeff Alton 09-14-2005 04:54 PM
There is a member on this board who has done it, lives in Singapore. I can't remember his name. He had sent me some pics a while ago, I will see if I still have them.
Jeff
stv951 09-16-2005 10:08 AM
How would you guys compare the power of an early 3.6 911 against a 996 ? Power to weight favours the early car
MuffinMan 09-16-2005 10:38 AM
This is true at lower speeds, but realize the large aerodynamic benefit of the 996 once you get into triple digit speeds.
On the street, my ~2600lb ~300hp 1977 911 feels more potent & zippy than a 3.4 996, imho.
Jack Olsen 09-16-2005 01:18 PM
An early car with a 3.6 is faster than a 996 on a track. But as 996 prices come down, the cost advantage may end up with the newer car.
Bill Verburg 09-16-2005 01:30 PM
996 are actully a very good underappreciated car, sort of like a 964. But the engines have a lot to prove before they convert any one to their worthiness as as successor to the 911 line.
GT3s on the other hand are to die for.
Bill Verburg 09-16-2005 01:33 PM
Stock 993 is a very good suspension design, but it is not inexpensive to change the rubber pieces to harder more track oriented versions, or monoballs.
It would be very interesting to see the 993 suspension t/p into a 911
Bill Verburg 09-16-2005 02:04 PM
Forgot to add that the one thing that cannot be transplanted from a 993 to a 911 is chassis rigidity, those things are rocks, even w/o a cage.
I'm sure that a full cage tied into all the suspension areas would be as good or better.
Jack Olsen 09-16-2005 03:10 PM
http://www.amracing.org/images/Olsen...1114503284.jpg
Henry Watts' car is probably the ultimate early car with a swap. In addition to a built 993TT motor, he's got a 993 rear end, a G50 (probably with custom gear sets) and a lot of the Smart Racing catalog thrown in for good measure. Plus, he wrote the book Secrets of Solo Racing, so he's no slouch behind the wheel. I usually qualify right behind him in the race series I occasionally run in, but that doesn't mean our lap times are even close. He's 10 full seconds a lap faster than me at Thunderhill, for example.
Here's a snapshot from a race start, which shows how quickly he's able to outdistance me in a straight line. As a point of reference, we were lined up in the same row before the green flag dropped.
http://forums.pelicanparts.com/uploa...1126912189.jpg
II6 09-16-2005 03:32 PM
This one's a sleeper.
83 SC
915 tranny.
sport bilsteins, 22/28 bars, 22mm adj. sway bars, 9" + 7" fuchs,
monoballs.
http://forums.pelicanparts.com/uploa...1126913326.jpg
http://forums.pelicanparts.com/uploa...1126913287.jpg
Jeff Alton 09-16-2005 03:45 PM
Details on the motor please.....
Cheers
II6 09-16-2005 03:57 PM
3.6L 964 engine
Intake system:
SDS EFI with Jenvey individual throttle bodies.
Custom machined throttle linkage.
Engine internal:
Ti valve springs, webcam camshafts.
Exhaust is custom built, using chopped-off Burch 42mm headers, and a magneflow 2in-2out exhaust (it's loud, so I block-off one outlet on the road, like Jack Olsen does).
