Sparkplug help
I have a 69 911E,with 40ida Webersm and I was wondering what spark-plugs are recommended. I hope something other than the $15.00 ones, though if that is what everyone is using I'll buy them.
Scott
Old 09-08-2005, 10:58 AM
Stock plug lookup shows:
Bosch - 3DP0 O.E. SPARK PLUG E,S; Gap=.024
NGK - NGK Traditional spark plug 1034 BP7ES 0.024
Warren & Ron, may you rest in Peace.
Old 09-08-2005, 11:08 AM
PMO recommends NGK BP5ES for carburated 911's. I followed their Recommendations when I switched my 69 to carbs because of the motor modifications I did. With my MFI I used the BP7ES and got great performance. In the 70's I'd buy them by the case at a wholesale place for 68 cents apiece. Oh for the good old days.
69 911 2.3Ez
85 928S
Old 09-08-2005, 07:21 PM
Jandrews's Avatar
For the B7-ES, I have read recommendations on this board for gaps of .028" - .032". I have also seen recommendations for .024". Does it really matter, and if so, what is the REAL recommended gap for B7ES?
By the way, I had the W3DP0's ($15 each) in my MFI 2.7 RS Spec motor, and they were WAY, WAY too cold!
Thanks,
JA
John
- '70/73 RS Spec Coupe (Sold)
- '04 GT3 (Sold)
Old 09-08-2005, 08:06 PM
I use NGK BP5ES.
I foul on BP7ES.
Maybe you should try the 7's and read your plugs. You'll know soon enough. I'd run the factory gap with stock CDI.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-09-2005, 12:50 AM
911Velocity's Avatar
I had fabulous success with the Denso iridiums when the Bosch plugs kept breaking up at high RPM. Try www.densoiridium.com for info. Expensive though at $12 each. Foe my application it was well worth it. Remember to use the correct heat range.
Best regards,
Gerry
84 911 Carrera (Supercharged), 67 427 Vette , 67 XK E-type Rdstr., 56 Vette
06 Cayenne Turbo S, 08 Vette Coupe, 57 Vette, 65 Chev Nova 327 4spd
65 Chev Nova 385 Race, 85 Chevy Rollback
97 Ford Exp. EB, 90, 91 Toy PU
Old 09-09-2005, 09:23 AM
