replacing strut inserts. Allingment?
If I'm just putting new strut insets in, is it necessary to have the front end alligned afterwards?
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
no, as long as you're not disconnecting at tie rod or control arm.
Bill G. '68 911 Ossi Blue coupe |
Thank You for the info, now its off to replace them.
Tom
Unregistered
Whoa.....
mechanically the struts won't change the alignment, but they might change the ride height, which in turn affects the toe in. If i were you (and you're glad I'm not) I'd at least take a tape measure reading of the fenders before and after. If the new inserts change the ride height very much you will prolly have to have the alignment checked. It all depends on how bad the old struts were. When I replaced my fronts with bilstein HDs, the front came up about 3/8" Later I replaced my rears with bilstein sports, it raised the car almost an inch! Obviously the old shocks were completely blown and and had almost no gas charge left in them. |
Sammy, This is true.
But if it does raise the car, could he not then lower the front to where it was before then the setting will be the same... Correct???
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
cycling has-been
that's what I thought, a few cranks of the 11mm in the front, and your back in business.
73 911T MFI, 76 912E, 77 Turbo Carrera |
