Weaver's Avatar
Do Neatrix bushings need grease?
Tried a search but could not find any examples.
Do Neatrix bushings need a coating of grease or silicon before install.
Thanks for your time.
Weaver
'88 911 Targa
'03 911 Turbo, X73 Susp.
'13 Panamera GTS
PCA member Central Indiana
Old 09-21-2005, 06:21 AM
Find some rubber-friendly lubricant to use to install them; normal grease will eat them.
Old 09-21-2005, 06:31 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Silicone spray and longer bolts make life easier when installing. The longer bolts pull the assembly into the chassis, instead of having to pound them in with a rubber mallet like I did.
Like Thom said, don't use petroleum grease. Turns the rubber to a sticky paste.
Kevin L
'86 Carrera "Larry"
Old 09-21-2005, 06:46 AM
Weaver's Avatar
Thanks Thom. I was thinking of using either Dow 111 or Napa Sil-glide on them upon installation.
Weaver
'88 911 Targa
'13 Panamera GTS
Old 09-21-2005, 06:53 AM
Weaver's Avatar
Thanks KTL. Where did you source your bolts?
Weaver
'88 911 Targa
'13 Panamera GTS
Old 09-21-2005, 06:58 AM
K-Y?
Old 09-21-2005, 06:59 AM
Weaver's Avatar
Whats K-Y's operating temperture range?
Weaver
'88 911 Targa
'13 Panamera GTS
Old 09-21-2005, 07:01 AM
Doesn't matter - you only need it long enough to get it in
Old 09-21-2005, 07:02 AM
Weaver's Avatar
Ok.......thats the end of this thread! Thanks for the help and good morning in California.
Weaver
'88 911 Targa
'13 Panamera GTS
Old 09-21-2005, 07:05 AM
All kidding aside, I've used it a lot when installing window and door seals in freshly-painted VW's.
Old 09-21-2005, 07:10 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Ace Hardware in my town has good metric selection of bolts. Since you're only using the bolts to pull the bushing into the body, cheap ones are fine. They'll obviously be too long once you get the assembly seated in the body, so the old bolts will still be needed.
Kevin L
'86 Carrera "Larry"
Old 09-21-2005, 07:14 AM
450knotOffice's Avatar
Yes. I'd use Dow 111. It really is an awesome grease for this job (oil return tubes too).
Old 09-21-2005, 09:09 AM
