Do Neatrix bushings need grease?
Tried a search but could not find any examples.
Do Neatrix bushings need a coating of grease or silicon before install. Thanks for your time.
Weaver '88 911 Targa '03 911 Turbo, X73 Susp. '13 Panamera GTS PCA member Central Indiana |
Find some rubber-friendly lubricant to use to install them; normal grease will eat them.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Schleprock
Silicone spray and longer bolts make life easier when installing. The longer bolts pull the assembly into the chassis, instead of having to pound them in with a rubber mallet like I did.
Like Thom said, don't use petroleum grease. Turns the rubber to a sticky paste.
Kevin L '86 Carrera "Larry" |
Thanks Thom. I was thinking of using either Dow 111 or Napa Sil-glide on them upon installation.
Thanks KTL. Where did you source your bolts?
K-Y?
Whats K-Y's operating temperture range?
Ok.......thats the end of this thread! Thanks for the help and good morning in California.
All kidding aside, I've used it a lot when installing window and door seals in freshly-painted VW's.
Schleprock
Yes. I'd use Dow 111. It really is an awesome grease for this job (oil return tubes too).
