450knotOffice's Avatar
Question How do I secure the Front License plate?
I would like to put a Euro Plate on my front valance but I have never had any sort of plate on there at all so I have no mounting hardware to speak of. The front valance has two slots in it that are about 5/16" tall and maybe 1/2" long. That's it. The problem I have is that access to the back of the valance is extremely tight and won't allow my hands enough space to get up there and secure a nut to any bolt I might stick through the hole.
How did you guys with the Carrera's (you know how tight it is in there) do this?
Old 09-21-2005, 05:58 PM
Friend of Warren
You can buy the US license plate bracket for the car (not sure if PP sells it or not and it snaps into the two rectangular slots on the valance. Then you have to fab up a couple of steel straps to extend out for the euro plate. On the other hand, maybe the eure bracket is available in the U.S.
Kurt V
Old 09-21-2005, 06:16 PM
Scott;
There are actually a couple of plastic inserts that snap into the holes in the bumper and the bracket is screwed to them. Buy the inserts and the appropriate screws and make your own bracket out of steel or aluminum flat stock, if you can't find the Euro version for sale.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 09-21-2005, 06:27 PM
RETIRED
Joe Bob's Avatar
Duct tape?
2012 ML350 3.0 Turbo Diesel
Old 09-21-2005, 06:54 PM
I tossed the license plate bracket and then drilled two holes in the license plate that lined up with the holes in the valence that held the bracket and mounted the plate directly to the valence. Only reason I'm running a front plate is I kept getting stopped for no plate but never got a ticket.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 09-21-2005, 09:22 PM
Thanks guys. I'll check this website's catalog to see if I can find a license plate holder.
Javadog, where can I find these plastic inserts you are talking about?
Old 09-21-2005, 10:14 PM
DW SD's Avatar
Scott,
I used threadserts (also called rivnuts). They are rivets with threaded nuts attached. You can install them into sheet metal and put an M6 (or whatever size) bolt through it.
Works great and very clean. I installed my rear license plate in this manner. I have the tool to install and have threadserts you may have.
Doug
1971 RSR - interpretation
Old 09-21-2005, 10:55 PM
Scott;
You need the following parts. They are available from a dealer. The plastic inserts may occasionally be found at a supplier that sells clips to body shops and the screws/washers can be had at a good hardware store but, for parts this cheap, its not worth much of your time to track them down. You'll need 2 each of:
999 591 354 02 plastic insert
803 955 637 rubber washer
N 011 524 7 steel washer
900 187 115 02 screw, 5.5x16mm
You may be able to get this stuff from somebody selling a front valence. It came with all new 911s.
JR
Old 09-22-2005, 03:17 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest license plate
Hope this will help.
Kees.
Old 09-22-2005, 03:38 AM
I was lacking a front bracket for mine, so I fit a round peg in a square hole. I bought two rubber expansion plugs (I'm not sure if they were 1/4" or 5/16") from Home Depot (in specialty fasteners) for the square valence bracket holes. I split a galvanized framing stud joiner in two with a hacksaw and cleaned them up with my bench grinder. With some creative re-bending and hole-drilling, I fabbed up two elongated "Z" shaped brackets.
I used nylon screws to mount the brackets to the rubber plugs (there's a brass threaded portion inside the plugs that expand them as the screw is tightened), and nylon screws and nuts to mount the plate to the brackets.
It's all very solid when everything's buttoned up and there's no metal-on-metal at the bracket-valence mounting point. It's a clean solution for less than $5.
Old 09-22-2005, 06:24 AM
I don't mount the front plate for driving. Only for inspection
I use black nylon ties to secure the plate to the front spoiler/grill section.
Warren & Ron, may you rest in Peace.
Old 09-22-2005, 06:43 AM
Unregistered
sammyg2's Avatar
The square plastic inserts are available from your FLAPS, as well as the screws that go into them. I had to buy them when I first got my car, I think I found em at Poop Boys.
Old 09-22-2005, 09:21 AM
911S Targa's Avatar
Here's mine (as you asked me before 450).
As you can see in the above pic, I used the stock US plate holder. I was lucky with the plate because the holes lined up perfect with these holes in the below pick.
The holes I'm speaking of are the ones with the white arrows pointing to them. I used 2 washers that were a little bigger then the above said holes on the back side of the plate holder.It's what I could do at the moment, just to have the plate on.
Bill
MID9 #4
if i cant play with it ,,i dont want to own it
Old 09-22-2005, 09:53 AM
jdowty3's Avatar
What's a front license plate for? Luckily, only the rear is required in MI.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 09-22-2005, 10:32 AM
I tossed the front plate years ago, to much weight
carrue529
1987 911 Carrera
S.Wong chip|ElginCams|GT3 oil pump|short gearing|Guard TB-Diff|22/29 Hollow T-Bars|monobloc calipers|Bilstein HD/Sport|Turbo tie rods|Strut brace|CobraMonza II seats|7, 9 Fuchs|Elephant polybronze bearings F/R|Wevo eng mounts|bypass cat pipe|M&K muffler
Old 09-22-2005, 11:17 AM
safe's Avatar
How about a "James Bond style" retractable license plate for when speeding in an area with traffic cameras.
Magnus
Old 09-22-2005, 11:30 AM
