Rouxzy's Avatar
replacing strut inserts. Allingment?
If I'm just putting new strut insets in, is it necessary to have the front end alligned afterwards?
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 09-17-2005, 05:54 PM
911SCfanatic's Avatar
no, as long as you're not disconnecting at tie rod or control arm.
Bill G.
'68 911 Ossi Blue coupe
Old 09-17-2005, 06:48 PM
Rouxzy's Avatar
Thank You for the info, now its off to replace them.
Tom
Ferdinand Porsche
Old 09-21-2005, 02:38 PM
Unregistered
sammyg2's Avatar
Whoa.....
mechanically the struts won't change the alignment, but they might change the ride height, which in turn affects the toe in.
If i were you (and you're glad I'm not) I'd at least take a tape measure reading of the fenders before and after.
If the new inserts change the ride height very much you will prolly have to have the alignment checked.
It all depends on how bad the old struts were.
When I replaced my fronts with bilstein HDs, the front came up about 3/8"
Later I replaced my rears with bilstein sports, it raised the car almost an inch! Obviously the old shocks were completely blown and and had almost no gas charge left in them.
Old 09-21-2005, 03:18 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Sammy, This is true.
But if it does raise the car, could he not then lower the front to where it was before then the setting will be the same... Correct???
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 09-21-2005, 03:48 PM
cycling has-been
bkreigsr's Avatar
that's what I thought, a few cranks of the 11mm in the front, and your back in business.
Old 09-22-2005, 07:50 AM
