LinkBack | Thread Tools | Rate Thread |
Go Speedracer, go!
What works to remove the glue left over from the engine sound pad?
I recently removed my engine sound pad. It was mostly laying on my engine and falling apart, so I just ripped it all out. Now I'm left with all of the pretty yellow/brown goo it was attached with. I scraped at it with a brush, but it's on there pretty good. What can I use to safely dissolve it? I would like to avoid removing or lowering the engine if possible, and avoid damaging the paint. Something spray on that I can rinse off with a hose after it does its job would be ideal.
1981 SC ROW Coupe |
I used goof off with a power washer. It work just ok. I'm thinking something that will dissolve adhesive would work better.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
I have no idea if this would work or not, but if I were in that situation I would try using some gasket remover, because I have it on hand, and know it is for automotive use. Works pretty good for getting off the goo left by old, worn out gaskets. Probably would have to scrub a little with the brush again instead of just rinsing away.
-Matt 1985 Targa |
Used Up User
Acetone works but it's not fun. I just glued the new pad on top & cleaned the edges.
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
I think I read on this forum that 3M adhesive remover works great. Is this true?
Southern Class & Sass
3M Adhesive Remover is what you want.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Go Speedracer, go!
1981 SC ROW Coupe |
quote]Where do you get this stuff?[/quote]
NAPA will have it. An auto-paint-supply store will have it. I've even seen it at Pep-Boys. Quote:
Why not install an Ap-biz sound pad? Here is a picture of the one I installed. You can order one from Pelican, or Ap-biz. I only had to lower the back of the engine in my Porsche about 2" to install it. I didn't even need to unhook any lines.
Go Speedracer, go!
1981 SC ROW Coupe |
Matthew “Sometimes the questions are complicated and the answers are simple.” |
you aren't hearing a difference b/c the old one was so far gone it had no noise insulation left - a new one will reduce the noise
no reason to remove all the old glue - just spray on new glue and go. I use the tube type around the edges.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Used Up User
Ian
