Go Speedracer, go!
SpeedracerIndy's Avatar
What works to remove the glue left over from the engine sound pad?
I recently removed my engine sound pad. It was mostly laying on my engine and falling apart, so I just ripped it all out. Now I'm left with all of the pretty yellow/brown goo it was attached with. I scraped at it with a brush, but it's on there pretty good. What can I use to safely dissolve it? I would like to avoid removing or lowering the engine if possible, and avoid damaging the paint. Something spray on that I can rinse off with a hose after it does its job would be ideal.
1981 SC ROW Coupe
Old 09-27-2005, 12:19 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
I used goof off with a power washer. It work just ok. I'm thinking something that will dissolve adhesive would work better.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 09-27-2005, 12:34 PM
mschuep's Avatar
I have no idea if this would work or not, but if I were in that situation I would try using some gasket remover, because I have it on hand, and know it is for automotive use. Works pretty good for getting off the goo left by old, worn out gaskets. Probably would have to scrub a little with the brush again instead of just rinsing away.
-Matt
1985 Targa
Old 09-27-2005, 12:38 PM
Used Up User
imcarthur's Avatar
Acetone works but it's not fun. I just glued the new pad on top & cleaned the edges.
Ian
'87 Carrera Cab
Old 09-27-2005, 12:55 PM
RAM RAM is offline
RAM's Avatar
I think I read on this forum that 3M adhesive remover works great. Is this true?
Old 09-27-2005, 01:40 PM
Southern Class & Sass
Dixie's Avatar
3M Adhesive Remover is what you want.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 09-27-2005, 02:34 PM
Go Speedracer, go!
Thanks for the feedback. Where do you get this stuff? Lowe's, Home Depot? Is it in a spray can or what?
1981 SC ROW Coupe
Old 09-27-2005, 03:13 PM
Dixie's Avatar
quote]Where do you get this stuff?[/quote]
NAPA will have it. An auto-paint-supply store will have it. I've even seen it at Pep-Boys.
I buy it in a squirt can. Squirt it on a rag, rub it on the glue. Use patience...
Why not install an Ap-biz sound pad? Here is a picture of the one I installed. You can order one from Pelican, or Ap-biz. I only had to lower the back of the engine in my Porsche about 2" to install it. I didn't even need to unhook any lines.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 09-27-2005, 03:28 PM
Go Speedracer, go!
Yep, I had to lower my engine about 2-3 inches to get the old one completely out. I didn't notice any difference when I removed it, so I don't see a need for it. I think because it is a euro it has less sound deadening materal anyway. My dad's 88 has always been much quiter. It's also not a daily driver so I doesn't bother me.
1981 SC ROW Coupe
Old 09-27-2005, 03:37 PM
PorscheGuy79's Avatar
I got the 3m stuff in an aerosol can, I have yet to use it but I imagine it would work great. The cans are hard to come by, I got mine at a local automotive paint store.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 09-27-2005, 03:47 PM
randywebb's Avatar
you aren't hearing a difference b/c the old one was so far gone it had no noise insulation left - a new one will reduce the noise
no reason to remove all the old glue - just spray on new glue and go. I use the tube type around the edges.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-27-2005, 05:37 PM
Used Up User
imcarthur's Avatar
Thank you, Randy. I too, saw no reason to remove old glue simply to replace it with new glue & then hide it all permanently under a pad.
Ian
'87 Carrera Cab
Old 09-27-2005, 07:59 PM
