Idle question
I just got a 1988 911 3.2. After accelerating and taking my foot off the gas to come to a stop. The RPM’s drop to 700 or so, bounce to 1100 then slowly settle to idle at 850. Is this bounce normal, or should the RPM's stop at 1100 and settle to idle?
Old 09-25-2005, 08:51 PM
Could be a number of things
- idle adjustment off
- idle position sensor not functioning correctly
- idle stabilizer valve not functioning correctly
- mixture off
there are home checks for these with the exception of the mix adjustment
todd
86 coupe
Old 09-25-2005, 10:04 PM
SMC SMC is offline
So this is not normal, what should the RPM's do if the car is
running right?
Old 09-26-2005, 07:06 AM
SMC SMC is offline
bump
Old 09-26-2005, 08:13 AM
Nine9six's Avatar
It should settle at 840 - 880 rpms without hunting.
Do a search on "idle hunting"...Tons of info, with as many possible causes and fixes.
Vacuum leaks
Temp head sensor
o2 sensor
MAF
The list goes on and on.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 09-26-2005, 08:19 AM
SMC SMC is offline
It is not hunting (at least don't think so?), it is more of a bounce (onece) and it dose settle
to idle. So when you take your foot off the gas to put in the
clutch to come to a stop. the idle drops to (?) then settles to
idle?
Old 09-26-2005, 08:34 AM
