HFR_Racer's Avatar
Lightbulb Cruise control servo diaphram leaking? Who's the expert on this?
I believe that the diaphragm contained within the cruise control servo is leaking on my 86 Carrera.
Symptoms:
1) Cruise controls activates ok.
2) Cruise control ACCEL works ok.
3) Vehicle slowly looses speed after the cruise is set.
Can the cruise control servo be rebuilt? Maybe a leaking vacuum line? Any hints are appreciated.
I'm going to check if the servo will hold vacuum this evening.
Thank you,
HFR_Racer
1986 Targa Carrera
Thank you,
HFR_Racer
'87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups.
Old 09-27-2005, 12:48 PM
HFR_Racer's Avatar
Talking Cruise control fixed....
I found the problem.. As I was changing the spark plugs I must've pushed against one of the vacuum hoses to the cruisee servo. The rubber was weak due to repeat heat exposure and fractured. This caused just enough of a vacuum leak to effect the cruisee control and make the vehicle slow when the cruise was engaged.
I was sad to see that nobody offered any suggestions to my original post.
Thank you,
HFR_Racer
Thank you,
HFR_Racer
Old 09-27-2005, 07:33 PM
I have the exact same symptom that just developed with my 87 and its cruise control. Exactly what hoses were cracked? I have identified the cylinder that is the cruise control, where the throttle cable exists. I have a long ride to Baltimore and back in the morning and would like to put some duct tape on the hose that is leaking.
thanks
eric
1987 911 Cab
2002 Avalanche
2002 Saturn ugh
1990 Suzuki RMX 250
1985 Goldwing
Old 05-17-2006, 09:02 PM
