Registered Loser
Question How does one "make" ignition wires?
I see these red ignition wires in pics of peoples motors and I assume they are somehow home made. Am I correct? I'd like to do a tune up of my 964 before winter and the cost of a set of (twelve!) ignition wires has me staggered. So how do I take my existing connectors and replace the wire? What parts will I need? Where can I get the best raw wire from? I haven't really screwed up anything big on my car in weeks and I'm itchin' to try. Are special tools involved? I understand the wire somehow "screws" into the connectors - but I'd like to have more of a clue before I go tearing apart my existing (expensive) wires.
Owner of a wrecked 944
Old 09-30-2005, 07:03 AM
I made a set for my Ferrari by first buying a set of pre-made ignition wires (red) from Taylor wires. Then I used a crimper to crimp on the connector after cutting wires to the correct length.
For the Porsche, I opted to buy a ready made set in Red from a well known supplier. I thought it was too hard to remove the old connectors and reuse them. And buying new set of connectors would cost just the same amount of money as a new set of wires.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-30-2005, 07:09 AM
jtkkz's Avatar
I got a set of magnecor 8mm for my 911 and cut it and installed the end connectors myself.
Doing it this way came out much cheaper.
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 09-30-2005, 10:25 AM
I just recently did this on my RSR clone. I used solid core wire from Moroso, crimp on clips from NAPA and Porsche OEM plug connectors. Very simple and easy.
Old 09-30-2005, 10:29 AM
Slumlord
Porsche_monkey's Avatar
So you got crimp on connectors for the distributor end from Napa? And Porsche dealers still stock the spark plug end?
Old 09-30-2005, 11:16 AM
Registered Loser
Okay, I'm game. I checked Summit Racing and they sell raw ignition wire in sizes from 7mm to 10.4mm. It seems to range in price from just over a dollar per foot to big $$$. Either way, if all I need is the wire and some crimp connectors, then making wires will be MUCH cheaper than buying a whole new set. So what do I need to know? Is 10.4mm wire worth the price? Are some brands or features better than others?
Old 09-30-2005, 11:59 AM
Slumlord
I think the stock is 7 mm, why go bigger?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 09-30-2005, 12:33 PM
8mm will be fine with a stock ignition system, anything much larger is a pain to get in the cap.
Invest in a nice set of terminal crimpers. Does the job faster and better, and will pay for themselves if you make a few wire sets for other cars.
Win
Old 09-30-2005, 01:56 PM
once you add new plug connectors to the picture, @ $20 each, you don't save a bundle, just a bit.
206 637 4071
Old 09-30-2005, 02:01 PM
Wider is Better
wholberg's Avatar
You can reuse the plug connectors if you really need to save $$$. I don't know what the lifespan of them is, though, and whether or not that is a good idea. I have reused them (years ago) when I just did not have the money for a complete set and the car ran fine, but the next time I replace the wires I bought a pre-assembled set.
Wider is Better
Old 09-30-2005, 02:24 PM
they need to be checked for proper resistance with an ohmmeter, usually around 3K ohm. occasionally they get a pinhole burned thru the casing which can spark to ground.
206 637 4071
Old 09-30-2005, 03:24 PM
Early_S_Man's Avatar
Porsche Crest
There is a great Beru PDF booklet that demonstrates the construction steps and details of the M3 threaded stud used on Mercedes and Porsche wires available for download here:
http://www.beru.com/download/produkte/stecker-TI05_e.pdf
It is 2.2 MB, and a rather painful download at 28.8 bps from a hospital room dial-up line ... compared to DSL!
If your ignition cables are putting on a 'light show' at night or in a darkened garage ... it is time to replace the wire between the replaceable connectors!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-01-2005, 06:31 PM
randywebb's Avatar
Warren - I hope you are doing ok (?)
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-01-2005, 07:39 PM
89turbocabmike's Avatar
Nice link Warren, hope your doing OK!? For hospital money, dial-up is a crime
Old 10-02-2005, 11:09 AM
Slumlord
So which part no.'s are correct for Porsche on that .pdf file?
84 Cab - sold!
Old 10-03-2005, 06:49 AM
