Front Clunk after Bilsteins install
1988 911 Cab. On driver-side front when hitting a bump I hear a clunk. Boge struts. I adjusted the front wheel bearing play thinking this was the problem. I jack up the front and grasp tire and shake. I can see some slight play with the shock. Anything to worry about? Maybe with in tolerence? Shut up and drive?
Jason 88 Cab |
How did you torque down the cap on the insert? You almost have to use the proper wrench to get it to the correct spec of 95 +/- 7 ft-lb. I wouldn't ignore it.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
wavey,
are you referring to the metal dust cap torque?
dave 1973,5 |
Would I tighten to that torque with the front driver-side jacked up? Or sitting on the ground?
Jason |
opps...Wavey...reread your post....forget my previous question. Shock needs to come out is what you are saying to tighten down (i.e. cap on the insert).
Jason Last edited by cicsprog; 09-30-2005 at 07:48 AM.. |
Right - the cap that secures the insert into the strut. I've seen those loose on other cars and it causes a clunk as the insert moves up and down inside the strut. I don't think you can get a wrench on it with the strut installed because of the dust cover.
yep...they were loose. I thought we had those things tight. No more CLUNK now. Drives better too! As usual this board is ACES! THANKS!
Jason |
