drag racing the short bus
BTW: Don, very nice. Mulholland run once you get that sucka in place...
Banned
Ya, it is a dampner all right!
Warren Hall Student
I believe it came with Cabs. Is this motor from a cab?
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
What?!?!
After re-reading the earlier posts, they now make sense. I was overlooking the cab references.
Honestly, the presence of the dampener had not registered with me till tonight.
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
Senior Member
Don,
Assume that you got this from Jim??? Pictures of the repair on the car pls!!! JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Licensed User
Is that specific to a G50 car or a cab? I know there was some kind of harmonic balancer (maybe it was a dampener??) for the G50 cars.
Very neat looking
Speed Yellow 911 Ruf BTR Conversion PCS Membership No: 266 Rennlist Membership No: 050315-5911 Ebony Black 2004 Jaguar XJ6 Titanium Grey 2003 Ford Focus |
It is for cabs. The cross mount bar is also different.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Very nice Don! Looks like new. Any mods? What kind of HP do you expect?
The cab engine mount and cross bar are different for a cab. I would change them both if you can get a set easily. Another option is to remove the shock component and replace it with a 3/16" bar welded up to add the rigidity. I found the cab mount caused shifting difficulties under heavy load on the track. If you want I can take a picture of the set-up.
John
1985.5 944 GTS |
Senior Member
Don,
Need to email you. Pls PM me your email. Thanks, JoeA
What?!?!
Joe, PM sent.
About the dampener... what the recommended approach? Keep it? Change it to a solid piece of metel? At this point, I don't have a preference.
