andycook's Avatar
Coilover Conversion Questions
What exactly is involved in converting my SC over to coilovers? Both front and rear.
Can ride height then be adjusted using the coilover sleeves or will the geometry of the rear control arms limit the height?
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
73 VW Beetle AutoStick
02 F250 4X4 (Parts Hauler)
03 Kia Sorento (Wife's DD)
Old 10-03-2005, 10:24 AM
Jeff Alton's Avatar
It all depends how far you want to take it an how much you want to spend...... First, why do you want coilovers? You can get plenty stiff torsion bars so unless you need big spring rates, it may be best to stay with the torsion bars. Adjustablilty, Something like a factory spring plate, WEVO one, or a Sway away one all have adjustment in them.
Now back to your question. You need new struts (rsr style) that should come with all the required bits an pieces. Try www.theracersgroup.com or www.smartracingproducts.com for prices. In the rear you will need new shocks (rsr style) and they should also come with all the bits and pieces, see above links. Take it a little farther and really open your wallet and spring for ERP 935 style front a arms and crossmember and 935 style rear spring plates.
Put all of this stuff in and you have a very adjustable suspension. Ride height is a snap by using the threaded perches on the shocks and struts. Toe adjusted seperately from camber on the rear. Up front you can change track, castor, camber with the adjustable a-arms. You can also still adjust castor and camber at the strut top as well.
I have custom valved bilstien struts/shocks with SRP hardware and got the 935 style front and rear stuff from TRG. I am very happy with all of it. It is lighter weight than the factory stuff as well.
All that said, it is a big bunch of change for upgrades that may or may not be better than staying with torsion bars.
Hope this helps a little.
Cheers
www.turn3autosport.com
Old 10-03-2005, 10:49 AM
andycook's Avatar
Thanks for the input Jeff. I am going to check out those sites and see what I am looking at. Probably scare me, but just think of the bling factor!
Has anyone ever modified factory struts to accept a coilover conversion kit?
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
Old 10-03-2005, 11:31 AM
Administrator
Jack Olsen's Avatar
Outside of dedicated track use where you need higher spring rates, there's very little gain with coils, which entail either 1) great expense to reinforce the chassis, or 2) gradual damage to your tub.
I recently went back to torsion bars in the front of my car. Now I can run wider tires there.
Old 10-03-2005, 11:43 AM
randywebb's Avatar
It seems that coilovers make sense under two conditions:
1. When extreme stiffness is required
2. when multiple tracks are run with very different conditions, and fast setup changes are required
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-03-2005, 11:58 AM
Jeff Alton's Avatar
One other thing you get is the ability to improve the front/and rear geometry. The front inside pick up point is raised 20mm with the 935 style stuff. In the rear, if you use raised inner pick up points, you can use the raised front outer spring plate mount as well. Obviously doing this in the rear requires considerably more expense to purchase and weld in the raised inner trailing arm mounts.
Spend your money where you want it. Some update/backdate bodywork at considerable expense for no performance advantage, some dump money into questionable engine mods, some go overkill on their suspensions, some even upgrade stereos...... you get my point!
Coil springs are cheap if you want to change the rates someday which is also nice.
Like I said in my first post, they certainly not required but I am very happy with my set up. My car does see a fair amount of track time but I do use it on the street as well.
Cheers
Old 10-03-2005, 12:36 PM
Cheers
I think we need pictures, sounds like a nice ride
78 SC all over the shop
74 911 Stock
Old 10-03-2005, 01:57 PM
Jeff Alton's Avatar
It is apart right now, but I can take some pics tonite and post them if you like. If you search my name you should find some. I am putting in the SRP smooth steering upgrade and another set of revalved bilstien struts tonite.......
Cheers,
Old 10-03-2005, 03:53 PM
What about going the route of a 964 conversion instead of a rsr set-up? Is that possible?
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 04-26-2010, 05:09 AM
