Maybe clouding the issue, but:
Really, what would be the difference between say a 2.7 RS spec engine and a 3.0L with Early S cams (and appropriate pistons / carbs)? Basically it's only 10% larger displacement and has the same stroke: Is that really enough to call the 3.0 torquey and not as peaky? Was the step from 2.0/2.2S to 2.7 RS also a big decrease in peakiness with an increase in torque? AM
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
Andrew, the difference is in the crank. The SC 3.0 Crank is heavier enough to make the car slower revving, and not as "alive" feeling. A Carrera 3.0 uses the 2.7 crank and thus can retain that early, lively, free revving feeling. This is all from what I read on the forum, and my own logic. I've never driven an SC or C3. I guess it's Carrera 3.0 or earlier for making an early feeling engine.
Could this be partially offset by using a lightweight flywheel?
Warren Hall Student
Lightweight flywheel, rods, and pistons can all contribute to a rev happy motor. I don't see why you couldn't make a 3.0SC based motor at least as rev happy as a stock 2.4 or 2.7RS.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
The 2 together, that's sure to make a difference.
Tru6 Restoration & Design |
Double Trouble
Early S cars like to run where the air is thin. Around town I rarely get into 4th gear. The cams come on crazy at about 4400 rpm and it starts to make the sweetest sound you have ever heard all the way to 7200 rpm, pulling hard all the way. They are really crabby when you hold them back. They have two speeds..idle, and Holy ****e! By comparison the SC is very gentlemanly, and civilized.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Bill is Dead.
I have GOT to drive some more 911s!!
I've got a 78 SC; 3.0L; CIS. I know it has SSI header/exchangers, and has been re-cammed. But that is all I really know about the work the PO did to it. Let me say, it screams compared to almost everything else I have owned. Now, reading this thread, I want to drive some others to get a real comparison!!
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Gon fix it with me hammer
- more displacement = more low end grunt the peakyness of the cams is less obvious on larger displacement engines - MFI throttle response 2.2S to 2.7 RS is definately a big decrease of peakyness even 2.4 to 2.7 differs a great deal :
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
MBruns for President
I've driven an S - and I have to say that my 3.4 drives much more like an S than my 3.2 carrera used to.
almost a stumble down low - but boy when the 993 ss cams come on line there is a rush towards redline - unfortunately kept below 5000 rpms at break in - but you can tell she is coming into her own at 5000 rpms. Can't wait to take the training wheels off.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
TIA
Andy |
Don
72T Coupe - SOLD :-( |
No camgrinder did not recommend them (the cams) He was great to work with - measured everything for me, made recommendations on rockers and such, in fact I just went to John and said, this is what I want... I got the recommendation for the 993 ss cams if I would do the exhaust too from several sources, especially not having to be emmission compliant.
My current trans is a 7:31 mag case 915, no LSD. With the 2.2S I used a 901 (911) also no LSD.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
