Long idle time...Poor performance
Does anyone have an opinion as to what happened here?
I kept the engine running at idle on the '87 Carrera for about 30-40 minutes while doing several small maintenence items (e.g., checking and filling the oil, checking the spark plug wires, just listening to the engine, etc.). When a took it for a spin, the car ran very rough with terrible acceleration. Absolutely lost the now familiar power band surge above 3500 rpm. Felt as if I was trying to pull out a tree stump. Panic and depression immediately set in. When I started it up about 4 hours later, there was a big cloud of white smoke, but the car ran as if nothing happened. At the moment, I feel like a lucky knucklehead.
Michael 1987 3.2 Carmine Red Carrera 1995 Midnight Blue 993 C4 1957 Silver Speedster Outlaw (replica) |
Your owners manual tells you to avoid idling your 911 since it's has dry sump oiling.
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
Live and learn, man. Consider yourself a wiser Porsche owner.
I see a lot of guys do this on our runs and I just shake my head. Don't people read the manual? Porsche advises against this in plain language. |
Perhaps you fouled your plugs with all that idling. The white smoke was it burning off. The car was fine after the "Italian tune-up."
Downshift |
I let my car idle (10 minutes) to dry off the engine (per instructions on the can) at the car wash last week. I had problems a few blocks away - thought it was moisture under the distributor cap (found some), and also cleaned off a burr on the fuel pump relay.
I did not think until now that it could of been anything else. Live and learn.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Designer King
Don't know if this is an urban legend, but I've heard that idling for extended periods of time causes increased camshaft wear. It is also wasteful, environmentally irresponsible, and , in some places, illegal.
BTW, why hasn't "Italian tuneup" joined the ranks of politically incorrect terms that several posters have taken offence to?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Large Registered Member
I resemble that remark ![]() ![]() ![]() I'm half "eyetalian" and take no offense! The other half, however, is German.... Go figure! ![]() ![]() ![]()
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
Thanks for the replies, guys!
I'm still not sure exactly what goes wrong when the engine idles too long with a dry sump oiling system--but I do know never to do it again. I'll check the plugs for fouling when I adjust the valves and change the oil next weekend.
Thanks for the replies.
Still not sure what goes wrong when an engine with a dry sump oiling system idles too long, but I do know it will never happen again. I'll see if I fouled the plugs when I adjust the valves and change the oil next weekend. Have no idea if "Italian tune up" is PC or non-PC, but it certainly got the Carrera back into good running order.
Well, besides possibly fouling the plugs (which is probably what happened to your engine), I've read that these engines apparently don't lube the cams very well at idle speeds.
Thread Tools | |
Rate This Thread | |
