Senior Member
Hi all,
I recently upgraded my breaks to the big red ones found on porsche turbo cars and am now having difficulty stopping my car. Can any of you tell me where I went wrong? I was told this was a great upgrade for my car. I followed the instructions to the letter and they look GREAT but the wheels bearly move anymore when I drive and it stinks like all sorts of hell.
-- Chief Architect and Mastermind, SCWDP |
It's probably your muffler bearings. Better call Motor Meister and ask them. If that doesn't work, get a cool collar from PartWerks.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
What?!?!
Dood! That looks hellasweet!
I think I know where you went wrong but I can't tell from the pic. Did you add the Armor-all to your tire tread to make them jet fokkin' black? I bet if you do that your ride will get all the chicas!!
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
I see the problem!! You neglected to paint the hub nut cover red also!!! The brake disc will stop rotating when the brakes are applied, but the hub (and hence the wheel) will keep on rotating since it is not also red! (the paint keeps the two tied together!) If you're out of red paint, use JB weld, worked for me!!
'86 Carrera Cab "The Grey White Whale" '98 Kirkham 427 Cobra(in rehab) '94 Dodge Intrepid ES(very Porsche-like) '99 F-250 SD Diesel(Cowboy Cadillac) |
Did you use a metric screwdriver?? Too funny!!
The sad thing is that you see this on occasion in my part of the world. I get a kick out of the massive rear wing on Nissan Sentra. |
GFCC
Oh and, "Did you do a search?"
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Are you going with white or black lettering? Maybe gold would look good.
Warren & Ron, may you rest in Peace. |
Pre Registered
Re: Big red Upgrade (Questions)
As I recall, you may need to switch to the fully floating red rotors for the best results. |
dave 1973,5 |
I don't think you properly broke in the pads. You're going to need some Pagid orange to take the shine off the red a little.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
turbo dreaming
LOL.
you are too much leland. and i thought i was crazy.
Princeton Wong 96' 993 Carrera 2...Turbo As seen on MaydayGarage: http://goo.gl/mGmZB In Excellence #191: http://goo.gl/BjOsn |
Do those brakes have Vtec?
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Did you bleed the brakes properly? This can cause stopping difficulties. As for the stink, it should go away after your pads are broken in.
Also, if you ever see any silver on the disc, make sure you use Ricer Red Brake spray to clear it up, it works wonders. Bwaaahhhhh, too funny.
Jay '08 E350 Wagon '74 914 gone '72 T gone |
She/Her
You might need to go buy a quart of elbow grease. And change your blinker fluid while you are in there. Always remember, the more stickers you have the faster it will go.
Gwyneth *she/her 1995 993 Guards Red 1984 911 Targa with a G50 (RIP) |
While you are making some “improvements” you might as well get some light bulb filaments and replace those fan belt buckles.
'78 SC |
You must clean with dielectric grease and use high heat VHT paint.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Slumlord
Put them on eBay.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Eat Oatmeal....its keeps you "regular" you know...
Ole Skool - wouldn't have it any other way |
This topic has been covered extensively........do a search
