THE IRONMAN
Performance Air Filter
Is the performance air filter at 200 $ a lot better than the ones at 25 $ on e-bay ? I look to install one on my 1984 Carrera with the adapter.Thank you very much for advice.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Make Bruins Great Again
You realatively new to the board so welcome. Use the search button and you will find a wealth of info with a wide range of opinions on stock versus aftermarket filters.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Friend of Warren
The search will tell you that the stock filter flows more than enough air. It is the exhaust you need to free up.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Administrator
Odds are, the performance air filter will reduce your engine's power output, and increase the amount of dirt going in.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Hi,
What about K&N stock(rectangle) replacement filters? Thanks! Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
durn for'ner
Further more, the stock filter / box has a very maintenance friendly design - makes it real easy for example to reach the upper rear right shock bolt...
Markus Resident Fluffer Carrera '85 |
Friend of Warren
I very much prefer the stock air filters, open up the outer cover to make more noise if you must.
