Can't be that simple.
I'm replacing the carpet in my 911. The rear seats appear to be held against the outsides with a slotted screw/bolt and slip onto a pin in the middle.
I can't get either side to move with a pretty big screwdriver--do I just need to lay into it, or is there some trick?
A J Burns '07 Guards Red Carerra 4S 911 Coupe w/Aerokit '86 Iris Blue Carerra 911 Coupe (given to my son) '63 Morgan Tiger Cub w/original Atomic 4 |
I had to take out those seat backs to install my bolt-in rollbar. If I recall the outside screws/bolts were not cooperative as you have found. I think used a big screw driver with a square shaft and an adjustable wrench on the shaft to turn it.
Good luck Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
Yea, it's that simple.
But I had to file the end off of a wide chisel to make a super-screwdriver and then put vice grips on it to get enough torque to get mine loose. Good luck.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
