| Registered |
				Ideas for blocking front vent after fan removal??
			Does anybody have any BTDT for the front vent to keep water from entering after you remove the trunk blower and all that garbage in the front? I would like to keep the mesh screen to keep the original appearance from the outside. I was thinking some thin metal and fabricate a block off behind the mesh with some sealer to keep it waterproof? Thanks - -Jeff
				__________________ Jeff | ||
|  10-23-2005, 03:57 PM |
| Registered Join Date: Mar 2001 Location: Marysville Wa.
			maybe a '68 and earlier style collector trough with drain hose.
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 | ||
|  10-23-2005, 04:33 PM |
| Registered |
			Hmmmm... '68' and earlier vent served no internal function for air circulation to the cabin? I didn't want to install a drain for water - just block it in the first place. This is all for weight savings. -Jeff
|  10-23-2005, 04:47 PM |
| Registered Join Date: Dec 2004 Location: Novato, CA
			You're pretty much going to have to install a drain if you keep the stock mesh. Blocking it off will allow water to collect and pool below the surface of the mesh; not a good thing, ianc
				__________________ BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 | ||
|  10-23-2005, 05:19 PM |
