Alignment Question
So the front tires (SO-2's) on my new '89 Carrera need to be replaced, 'cause there's no tread left on the inner 20% - My PPI tech just said to check the toe in when I replace the tires, but the shop that did the 45K suggests it needs the "full meal deal" alignment.......How extensive an alignment do you all recommend?
Formerly bb80sc
Well, if you have a lot of negative camber and too much toe, you can get what you are seeing. I guess I'd go the whole way and get a full 4-wheel alignment and a corner balance as well. You could go like -1 degree camber front and -1.5 camber rear, depending on how you drive. You can probably go stock on camber and caster settings. If you have never had a corner balance, and your car is off, the difference is amazing.
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
