I would rather be driving
jpnovak's Avatar
Wurth SKS coverage
I am going to buy some Wurth SKS to patch some areas on my targa that is disassembled for paint. I need to coat a few areas along the vertical fender support, rocker and would like to recoat the engine bay.
How far will one liter go?
Old 10-27-2005, 07:41 AM
Hi Jaime,
I used less than a litre for the engine bay.
Just be sure to mask the car well; when you "splatter paint", it really does splatter!!!!!!!
Andras
Andras
1983 911SC The Chocolate Kiss
1998 Audi A6 Quattro (Family Car)
2002 Audi TT Roadster (Wifey's Car)
1992 Mazda Miata (Daughter's Car)
1991 Honda VFR750F Interceptor
1982 Honda VF750S Sabre
Old 10-27-2005, 11:10 AM
Andras
Did you use a Wurth gun or just a regular gun and how did it come out
LM
83 SC
Old 10-27-2005, 05:14 PM
joefrantz's Avatar
As a comparison,I just did a gas tank (from bare metal) and used the best part of a liter to get complete coverage. If you're trying to refresh an existing finish and not starting from bare metal, you should get better (+ 30-40 % ?) coverage.
The process splats out small lumps of the stuff rather than an even spray. Much like a drywall texture gun, if you've ever used one. The first few passes over bare metal leave a lot of the metal shining through.
Joe
Joe Frantz
73 911 T
Old 10-27-2005, 08:37 PM
Hi Jamie,
I used a splatter gun purchased at Harbor Freight; it is almost identical to that by Wurth, but costs only about $8.- The one down-side is you have to improvise with the paint container. I happened to have made one from another cylindrical container (it was a plastic mustard bottle) that had a screw top which fit the splatter gun's threads. It was also just the right length to have the splatter gun's feed tube go down to the bottom of the bottle.
It came out wonderfully. As Joe said, you should plan to put on two light coats (don't all sprayers say that ??!!), rather than one heavy coat. I have pictures, but they are paper prints, and I don't have them at the office, so can't scan them. But if you wish, I'll bring them, scan them, and you can see that it's all worth (Wurth????) it.
I'm planning to do the trunk also, but there is so much more stuff to mask, that I'll need lots of time to do that.
Don't forget - preparation is everything!!!!!!
Andras
Old 10-28-2005, 04:38 AM
I used about 8 liters for the entire bottom of a 914
http://www.phoenixhobbies.com/html/paint.html
Scroll down a few pictures to see it in progress, I used the Wurth gun and it works very well. For the small area you want to do 1 liter will be plenty.
Old 10-28-2005, 05:38 AM
