ThePointman's Avatar
Send a message via ICQ to ThePointman
Question Distributor Cap Seal?
Is there supposed to be a seal on the distributor that the cap rests on then seals? I have been driving my car in the rain and as there is no seal so the inside of the cap seems to have moisture condensing on it and then the engine runs rough.
Old 10-29-2005, 04:29 PM
kqw kqw is offline
Yes,
It fits over the dizzy shaft and then you install the rotor.
The Fox
Carrera
Old 10-29-2005, 08:23 PM
On mine there is metal on cap no rubber. So this isnt factory?
Old 10-29-2005, 09:14 PM
kqw kqw is offline
On my carrera, it's just a black plastic type disc that centers over the dizzy shaft. No rubber....
I wouldn't think that this seal would prevent moisture but serves to keep the dizzy mechanism free of any contaminates.
I would double check your cap for cracks etc.
Are you running OEM wires?
The Fox
Carrera
Old 10-29-2005, 09:40 PM
Yes I am running OEM wires. I just got the car on the 18th of this month and it is my first pcar. I checked the cap it seems fine. I am going to check in the morning but I do not remember seeing a plastic piece on the dizzy just plastic dizzy cap on metal. It has been raining here allot and I just cant help driving fast. But my no starting problem this morning happened right after I washed the car. And I did give the rear lid grill a good scrub and rinse.
Old 10-29-2005, 09:47 PM
kqw kqw is offline
A fine crack in the cap may be a little difficult to see. Try slightly flexing the cap to reveal cracks.
Does you cap have a black plastic covering over the orange plastic?
Shoot a picture of the dizzy asm. and post it.
The Fox
Carrera
Old 10-29-2005, 09:59 PM
Will do in the morning for sure. Thanks for the help I really appreaciate it.
Old 10-29-2005, 10:02 PM
The distributor cap needs to be waterproofed. I put a bead of strip caulk on the rim of the cap before clamping it down to keep the moisture out.
You will be able to drive off after this soaking like I did without the slightest hint of a miss.
Cheers,
Joe
Old 10-30-2005, 07:11 AM
Cheers,
Joe
That is exactly what I was thinking I would do. Put ring of silicone on the bottom of the cap.
Old 10-30-2005, 07:13 AM
I've done the silicone but the problem is getting the cap off afterwards. That's why I use strip caulk now.
Old 10-30-2005, 07:18 AM
What is strip caulk and where do you get it? Can you take a pic of it applied?
Old 10-30-2005, 07:21 AM
You can get it at any auto parts store and it looks like strips of putty on wax paper that you can peel off just like the body shops use to waterproof between fender/body seams.
Old 10-30-2005, 08:23 AM
Ah I have some grey stuff like that for sealing my trailer seams. Maybe that will work.
Old 10-30-2005, 08:25 AM
That's the stuff!
Old 10-30-2005, 08:26 AM
I will give it a go then. Right after I check the cap for cracks :-)
Old 10-30-2005, 08:29 AM
There's only one crack that you need worry about IMHO.
Old 10-30-2005, 08:34 AM
Stay on Target ...
Old 10-30-2005, 08:36 AM
Ok so I used some of the trailer seal to seal the plastic lid to the distributor cap. Seems kinda funny that the water runs right in through the decklid and drips right onto the top of the dizzy.
Old 10-30-2005, 12:02 PM
Irrationally exuberant
ChrisBennet's Avatar
I bet DowCorning 111 would work in that application. It never hardens so you can just wipe if off.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-30-2005, 12:36 PM
