porschett's Avatar
Red face Split the case...Look what I found
Found this during my inspection after splitting the case.
It seems like what's exposed is a tube that goes from the thermostat to the oil pump.
Can I use JB Weld to fill this?
What could have caused this?
David Nguyen
1987 930: 2700 lbs, 408 RWHP/405 RWTQ
930 pics: http://alturl.com/899f9
930 Engine rebuild pics: http://alturl.com/25qcy
Old 10-30-2005, 09:59 PM
PJMARKOW's Avatar
Thumbs up
No, that is quite common. I had the same in my 1977 930 case when I split it. Ok to leave it as is.
Cheers
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 10-30-2005, 10:16 PM
89turbocabmike's Avatar
No Worries, it should be that way. You can clean up the flash(edges) abit when you pull the oil bypass system apart.
Old 10-30-2005, 10:21 PM
porschett's Avatar
You guys kidding me? Whew, that''s good news, but why would they design it like that?
On a side note...The head stud Gods must be smilling upon me. Took all but 30 minutes to do remove 24 studs! Just double nutted the studs and it broke free. No heat needed. At first, I thought this is too easy, I must be pulling out case savers or something. No way it's this easy.
Of course, there's always one bad apple...took a stud extractor to the stubborn stud and it bit in no problems. I was expecting the worse from all the past posts here. Whew.
Old 10-30-2005, 10:29 PM
Wer bremst verliert
JohnJL's Avatar
Yeah, my case was the same...didn't look cool, thats for sure...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-30-2005, 11:04 PM
oneblueyedog's Avatar
I had no problem with that area on the inside. On the outside of the case after the rebuild, this sleeve to case area leaked. I solved it through an archived article here. Look on the outside of the case and you'll see some slots with the sleeve visible. One is outside of the oil cooler pedestal and one is on the inside. I had to J B weld the 2 slots. Search the archives.
It's not so easy to fix this in the car since you have to do a partial engine drop to remove the oil cooler. You may not ever leak there but if you JB while your case is split it's an easy fix. Just make sure it's clean before you JB the areas. I wouldn't use JB inside the case.
78SC coupe, Silver Metallic
Old 10-31-2005, 04:17 AM
porschett's Avatar
Thanks for the tips everyone. I'll try the JB weld on the outside.
For those interested, here's the link to the area oneblueyedog was refering to...
Source of Oil Leak
David Nguyen
Old 10-31-2005, 06:02 AM
