JBaez's Avatar
trying to troubleshoot emissions on 3.2 Carrera
All,
I am in the process of trying to figure out why I did not pass TX state emissions. it's a 2 speed test...idle and 2500 rpm.
everything passed except CO was too high on 2500 rpm test.
Here is what I have done so far:
disconnected 02 sensor - no change
reconnected 02 sensor - no change
tried cleaning the connections - no change
bought a new 02 sensor - no change
connected brown CA emission wire to DME - no change
checked to make sure mixture set for high altitude under seat -
still no change
took off mass air flow and reset the spring in both directions- no change to allow it pass without increasing HCM's.
changed setting for mixture and makes HCM's go too high to pass
I can get it lean but HCM's increase when I do. HCM in texas needs to be below 200.
I even tested the brain with another one and no change..ran the same way .
bottom line is that for some reason, I think the car just is not recognizing the O2 sensor!
Anyone have any thoughts on what it could possibly be..spent 5 hours on this today and I am at a loss for words. Scratching my head. Would love to hear from the techies.
Thanks!
John
1988 Porsche 911 Targa - 210K miles
Red / Black
1989 Porsche Carrera 4 - 59k miles
Red / Black
1980 Porsche 928 - 5 speed / Cashmere beige / 183k miles
Old 11-03-2005, 07:45 PM
ewave's Avatar
I had a euro premuffler on my 1987 Carrera 3.2 DME in Dallas, and it wouldn't pass. Had to put the CAT back on... sounds similar to your problem.. Bad Cat perhaps?
Paul
2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS.
Old 11-03-2005, 08:18 PM
JBaez's Avatar
I have a fabspeed euro premuff and the mechanic said it should still pass but towards the end he was really beginning to suspect that might be the problem.
Red / Black
Red / Black
Old 11-03-2005, 08:52 PM
ewave's Avatar
Well, that'ss your problem!! LOL
Paul
Old 11-03-2005, 09:15 PM
Large Registered Member
PatrickB's Avatar
See if you can borrow a Cat from anyone nearby!
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 11-03-2005, 11:28 PM
How's your ignition system? I think you've been bumping your head on the mixture scene enough, now might be a good time to look somewhere else.
Cheers,
Joe
Old 11-04-2005, 04:31 PM
JBaez's Avatar
I also replaced the rotor and cap and the car was running fine. any thoughts what else in the ignition it could be?
Red / Black
Red / Black
Old 11-04-2005, 07:07 PM
PatrickB's Avatar
If Texas DMV is as strict with emission requirements as CA is, that thing will NEVER pass without a CAT! If you don't have a CAT, see if you can borrow one from a fellow Pelican in your area.... They aren't exactly cheap....
Old 11-04-2005, 07:47 PM
Does the engine seem to have a slight miss? Regardless, you might want to pull your plugs to see what they look like.
Old 11-05-2005, 08:33 AM
JBaez's Avatar
I had not pulled any of the plugs yet but they only have 15K on them. I am going to pull them just to make sure. People say that the car should pass without a cat but I am not so sure now....
Red / Black
Red / Black
Old 11-05-2005, 08:38 AM
ewave's Avatar
My EXPERIENCE was that my car (1987 911 Carrera) would NOT pass without the CAT.... This was two years ago, in Dallas Texas on the Rolling emissions test..
Your problem has been diagnosed.... If there was a way to get a car to pass strict emissions without a CAT, don't you think they would design the system that way from the factory?
Duh!!!!!
Paul
Old 11-05-2005, 02:14 PM
