CIS (82 SC) Cold Start
82 SC will not start. At all. Does not fire at all. I am getting a spark; I do not smell any gasoline (there is gas in the tank). Ran perfectly, put it away for a week, and now the car is not even interested in starting.
WUR has about 200 miles on it.
Old 11-07-2005, 05:55 AM
Spark is good, now you need fuel....have you checked your red fuel pump relay? fuel pump(should be whirring with the ignition on , how old is the accumulator and fuel filter? is fuel getting to the injectors?
do a search and find volumes on these topics.
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 11-07-2005, 06:26 AM
1. You won't hear the fuel pump, it only runs when the engine is turning over (cranking or running).
2. With your comment about the new WUR I suspect you're not telling us the whole story.
Old 11-07-2005, 08:02 AM
Somatic Negative Optimist
Gunter's Avatar
With ignition on, remove the air filter cover, reach in there and gently lift the air sensor plate lever; do you hear the pump running? injectors hissing? (Bentley 201-7)
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-07-2005, 08:21 AM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
I'm getting 2 stories here:
1. fuel pump will run when ignition turned on
2. fuel pump will not run unless engine is turning over (starting or cranking)
From a noob, which is accurate?
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 11-07-2005, 08:51 AM
You can make it do 1, but it's 2.
Old 11-07-2005, 09:36 AM
Gunter's Avatar
Normally, the pump will run only when cranking the engine on start. However, you can mimic running conditions by turning the ignition on, then lifting the air flow sensor lever to get the pump running. Why don't you try that? You should hear the injectors hissing.
On the other hand, if the pump runs when you turn ignition on, (without cranking) it means that the sensor plate contact switch is misadjusted. (That switch is also called "Roll-over switch" meaning it'll shut off the pump in case the 911 is flipped over)
I suggest you get the Bentley repair manual; wonderful stuff in there to make you understand your car better.
Old 11-07-2005, 10:41 AM
ianc's Avatar
If the fuel pump is working, it is probably the cold start valve. Check electrical connections on back of the valve (on rear of throttle body), the solenoid, and at the thermotime switch in driver side chain cover.
A fuel pressure test is always a good thing to start with here...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 11-07-2005, 11:52 AM
Thanks for the tips. I've always been able to hear a whirring sound on CIS cars when the ignition was on; I thought that was the fuel pump. I'll pull the airbox cover off and lift the lever and see what happens.
I do not believe that it is a fuel pump relay (I swapped it with one of the black ones, but maybe that would not work), and my experience with cold start valves is that CIS engines will at least try to start on a warm day (80 degrees plus here) even with a bad cold start valve. This car has NO indication of wanting to crank.
99% that I am not getting fuel, but I am still not sure why.
I'd swap the red relay from my '88, but it is in the shop!
Old 11-07-2005, 01:17 PM
vash's Avatar
stick any black relay in for a temp check.
poof! gone
Old 11-07-2005, 02:28 PM
ruf-porsche's Avatar
Wrong Relay from an 88.
88 use EFI and 82 use CIS
cantdrv55's Avatar
If you're not getting fuel, it could be a bad fuel pump check valve (it's in-line with the fuel pump), the pump itself or fuel filter. I had the same problem with my 79SC. I replaced all three.
Old 11-07-2005, 02:35 PM
OK, I pushed the lever up, and I get a noticable buzzing, presumably the fuel pump.
I'm not sure what that tells me. I let it run for awhile, and still no indication of wanting to start.
Check valve?
Old 11-07-2005, 04:51 PM
I believe that the relay is the same, however. EFI and CIS both use an electric fuel pump!
Old 11-07-2005, 04:54 PM
cantdrv55's Avatar
Check valve?
I'd have someone push up the lever while I sat near the fuel pump to make sure that the buzzing is coming from there. I never could hear my pump over the whine of the CDI box when I stood in the back of the car. If you can definitely hear the pump and there is still no fuel, I'd replace the check valve and fuel filter. Two years ago when my fuel pump died, I ordered a new one and the check valve came with it.
Old 11-07-2005, 05:31 PM
Try using starting fluid to start the engine.
Old 11-07-2005, 05:40 PM
I tried a little bit of starting fluid by putting it in at the toilet seat. However, I am afraid to use too much, and have an airbox explosion.
I did about a 1 sec spray. Tried 3 times. No luck.
Old 11-07-2005, 05:46 PM
Fuel pump is running.
I've been told that the check valve is only an issue when the car is hot, and I remember replacing one about 20 years ago in a 2.7 car, and the problem was hot starting.
I'm baffled.
Old 11-07-2005, 06:13 PM
ianc's Avatar
I'm baffled.
Do you actually have gas out the injectors? Pull one and see while you have jumped the safety switch or are holding the sensor plate up. If no gas, look at filter or a blockage in the line. If gas, then look at cold start valve and do a fuel pressure test.
ianc
Old 11-07-2005, 06:23 PM
Have someone spray the starting fluid into the airbox intake snout while you crank the engine.
The last time when you spray the starting fluid into the toilet seat was it up or down?
Did the engine try to start or did it just crank?
Old 11-07-2005, 06:38 PM
