1972_911T's Avatar
Pre 74 Style Exhurst On 3.2 Engine
If I want to keep my authentic 1972 exhurst sytem on my transplanted 3.2 engine do I need a special exhurst to fit the 3.2 or will any pre 74 exhurst and HE's fit my 3.2? My engine is a euro version with no oxygen sensor.
Old 11-14-2005, 09:06 AM
DW SD's Avatar
Though yours is a Euro motor, I think yours should have an O2 sensor. I think you can use the early HEs, but you may have to install shortened exhaust studs OR use a washer stack to take up the difference in flange thickness at the exhaust port.
You may want to run an O2 sensor and install an O2 bung into the HEs.
Doug
1971 RSR - interpretation
Old 11-14-2005, 10:58 AM
skinnerd's Avatar
They make a set of SSI's just for 3.2's (different exhaust flanges than say 2.7 or smaller motor). I had a threaded collar welded into the left SSI into which my O2 sensor is installed. Any 73 and earlier stock exhaust will bolt right up.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 11-14-2005, 11:08 AM
1972_911T's Avatar
Mine definatly doesnt have an O2 sensor alot of the euro's dont it has a bung screwed into the dansk cat replacement pipe where the o2 sensor should be and the connector for the o2 sensor has a weird plug in it that I presume must overide the system. I posted about this in the past when I first noticed it didnt have one as I was under the impression the motronics wouldnt work without it and a few other euro engine owners confirmed theres was the same.
Old 11-14-2005, 12:40 PM
1972_911T's Avatar
Will the early HE's have less gas flow than the backdated ssi's that are intended for the 3.2?
Thanks Steve
Old 11-14-2005, 12:52 PM
Got a clean pair of early HE's if you're interested. Here's a pic.
Old 11-14-2005, 02:48 PM
Steve,
I am looking in to the same swap very soon, and my research show that the stock HE from the 72 will be like headers. All you need to do is change the studs.
Derek
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 11-14-2005, 03:33 PM
Jeff Alton's Avatar
Changing studs is not a simple task. I would be more inclined to trimming them or using washers between the nut and the flange....
Cheers
www.turn3autosport.com
Old 11-14-2005, 09:40 PM
SteveM911's Avatar
I fitted early 72-73 style heat exchangers to my modified 3.4 engined Carrera, used washers rather than shortening or removing the studs, a bit of a fiddle, but doable, I had rusty old headers on but needed heat for the winter in the UK,
Did not notice any difference in performance although I probably lost 2-3 hp.
Steve (Strosek34)
86 - Carrera 3.4 LWT
www.impactbumpers.com
Old 11-15-2005, 12:21 AM
Senior Member
Thanks Steve
Do not believe that there are any major differences between the early HE's and the SSI design. SSI may have changed the flanges in several models, and added the O2 sensor bung but believe that the tubing size is the same. May be wrong.
The major difference is that when you buy the SSI's, they are the last set of HE's you will EVERY buy for the car! They are stainless and will not rust out like the factory HE's do every few years, with the loss of heat and defrost up front. Plus they just look nice and preform!
Joe A
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 11-15-2005, 12:27 AM
