RAM RAM is offline
RAM's Avatar
Question 75 Won't start after running previous day
Need help! I have searched the threads and I was not able to find a similar situation (not that there wasn't one). I searched back about 12 months and nothing.
Here's the situation: Last weekend I drove around all day in my 75. It was a mixture of stop and go as well as a couple of long, high-speed hauls. I must have stopped and started about 8 times. Drove home, parked the car and let her rest for a day.
Then, the following morning, I went to start the car only to find that it would not. The car cranked but would never start. I checked the ignition and all was fine. Fuel in the tank and good pressure. Not bad fuses or relays.
Later in the week, I tried to start and it started and ran fine.
Any ideas why this could be?? Your help is appreciated.
Old 11-18-2005, 07:05 AM
Coral Red Syd's Avatar
Had similar issue with an 84 targa and it was the DME relay. 75 doesn't have one of these I'm pretty sure, but it sounds electrical. Rule one, check the electrical otherwise, check the electrical.
Coral Red Syd - "For Those Who Love to Fly... On The Ground"
Old 11-18-2005, 07:33 AM
RAM RAM is offline
RAM's Avatar
Other than checking spark, what else could it be? I had spark but it would not fire.
Old 11-18-2005, 09:27 AM
scottb's Avatar
Something fuel related? Bad fuel pump, or clogged filter?
1984 Targa
Old 11-18-2005, 09:50 AM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
You said you checked the red fuel pump relay right?
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 11-18-2005, 09:58 AM
Designer King
Paulporsche's Avatar
Check the output of your battery. All those starts may have drained it, while the longer runs may not have been enough to recharge. Sometimes on these cars, there is enough power to run the starter but not fire the engine.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
RAM RAM is offline
RAM's Avatar
acapella8 - I did check the red relays.
Paulporsche - I didn't know that. So the battery could have enough "juice" to crack but not start the car. I crancked on the started for a while and it nevet caught. If the battery was low I would assuem that it would have run down fairly quick.
As far as the clogged filter or bad pump. Why would the car start after sitting a bit longer, even after I tried to start it. Is it possible that I flooded the intake and therefore wouldn't start?
Old 11-18-2005, 11:53 AM
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
That happened to me last weekend and it was the battery, thankfully.
Old 11-18-2005, 11:56 AM
RAM RAM is offline
RAM's Avatar
I have a hard time believing that considering I cranked on the start for a while.
If this is the case, what should I check? I replaced the battery about a year ago.
Old 11-18-2005, 11:59 AM
vizail's Avatar
RAM
Sometimes the simplest things will make you crazy. A few days ago my 82 SC died on me. I had to push the Targa back to my garage.
I rest for a while and then turn the key on and notice that the fuel pump was off . I move around the cables in the fuse box and a spark jumped. One of the cables that supply electricity to the rellay and Fuel Pump was loose. I just clean it and put some dielectric grease in the cable and reinstal it and "presto"
Hope I can be of some help..!
Vic
Old 11-18-2005, 12:11 PM
RAM RAM is offline
RAM's Avatar
It's killing me. I'll just take it out again and wait a day to see if it happens again. If it does, I suppose I'll have to look at everything a little closer.
Old 11-18-2005, 12:16 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
Check the voltage at the battery with the engine off (if you can't start it, it helps!). Is it low? Have you checked it when it was running recently?
If it's low, throw it on a charger for a little while and see if it fires up. If it does after charging for a while, then your charging system is probably not doing it's job well, or the battery is losing it's ability to hold a charge.
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 11-18-2005, 12:19 PM
RAM RAM is offline
RAM's Avatar
In this case, I did not need to place a charger on the battery because it crancked up the following day. This was a full day after I drove the car.
If I attempt to start the car today I have no problems. It's only when the car have been run for a while and it has time to sit. I was thinking it could possibly be the cold start valve satying open or something.
Old 11-18-2005, 12:36 PM
Ram,
If your cold start injector does not work, the car will crank but never fire. I can't tell you why it wouldn't work one day and then be fine the next. The cold start injector gets power from the starter (it only runs when the starter is engaged) then it goes through the theromtime switch on the drivers rear of the engine. It sounds like you aren't getting fuel from either a bad connection to the fuel pump, or a bad connection to the cold start injector.
Don't spend too much time looking for the red fuel pump relay, 1975 did not have one.
Rex
1975 911s
1997 Saab 900s
Old 11-18-2005, 12:52 PM
RAM RAM is offline
RAM's Avatar
Well, I'll just have to see if it happens again and check the cold start valve if it does.
THank you all for your suggestions and comments. This board is GREAT.
Old 11-18-2005, 12:53 PM
