LinkBack | Thread Tools | Rate Thread |
A bit itimidated to remove outer wheel bearing- adjustment sounds simple...is it?
I have the dust covers off and I'm considering pulling the the adjustment nut off so I can remove the outer bearing, inspect and re-pack.
The re-adjustment sounds simple. I have heard from the 'man' (John Walker) to just screw the adjustment screw finger tight. Is it really that simple? My struts are off of the car completly so I can really do the shake test with the wheel at this point. Thanks. |
It is just that simple. Do make sure your contact surfaces are not marred.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I was taught the old VW technique
Crank the nut down fairly tight, then back it off untill you can just move the washer with a big screw driver. Anybody??
Dan '86 911 Targa Driver '76 911 Targa 3.0 Track Toy 46mm PMOs, 10.5/1 J&E,Web Cams, Wide Body fenders, 23mm and 30mm Hollow T-Bars, 930 Sway bars, Bilstein Sport Shocks, Plastic Bushings (too damn squeeky) |
It is that simple. I've used the screwdriver technique too.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
You've done the hardest part already...
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
Since your taking the outer one off anyway why not buy a grease seal (perhaps 2?), take the hub off clean both bearings with solvent, repack with grease and then reinstall? How long has it been since this was done on the car?
yup, tighten it snug. then loosen to adjust
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
Just replaced bearings and races last night. Fun project. No problems>
Reverend Ray 84 Carrera Coupe "DAS-V2" GruppeB #2119 Volvo V70SE-Wife mobile Nissan Frontier-Home Depot mobile |
One thing that should be noted, when you cinch the bearing down and then back it off, ALWAYS be rotating the hub as you tighten so you do not score the races.
Paul S "Those who say it cannot be done should not interrupt the people doing it" |
Yep - back it off until the thrust washes just moves side to side. It' s that easy.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
good point on the rotating part
Southern Class & Sass
The "crank the nut down, then back it off until you can just move the washer with a big screwdriver" technique", and "rotating the wheel as you turn the wrench”, are correct.
I'll add two other suggestions. First, before you take it apart, slide the washer around a bit to literally get the feel of how tight it should be. Second, pull the hub and rotor off the car completely. Then you can repack (or replace if needed) both the inner and outer bearings and install new seals. If you only repack the outer bearings, you're only replacing about 20% of the grease.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Hi IAN, You really need to remove the front hub to do the job right. I don't know what year your 911 is but you will have to take the solid brake line off the caliper to remove it. This will entail a brake bleed after you are done, do a search on that too. Keep all parts separate, left and right side. Is the Bend Brewery still there? They used to have the best stout ever. Let us know how the project is going.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
As posted in another thread on this topic....
by FAR.... the easiest way to get those pesky dust covers off is here--> http://forums.pelicanparts.com/show...D+cap+AND+clamp - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Update: and a few more questions
I have a 72 2.4 911 T.
I removed the left strut entirely as I'm in the process of replacing shocks, upgrading to turbo tie rods, new ball joints and a wheel bearing inspect/repack. I got a big flat screwdriver under the dust cap and took it off in about 20 seconds. The entire hub is off. Does the thrustwasher test/finger tight method still apply if the wheel is off and sitting flat on the ground? Or does it only apply if the wheel is sitting vertically mounted on the strut/car. I was thining about this last night and wondering. I pulled about a cup of grease out from the cavity between the inner and outer bearings. Is this correct? I will obviously re-pack the bearings but do people fill the cavity where the spindle sits as well? Or is this grease that has flung out of the bearings? I need to remove the inner grease seal and then carefully clean both bearings and re-pack. Anything else? |
