Nitrometano's Avatar
Spark Plugs for High Compression
Hi, I woul like to know what is a best choice for spark plugs for a 1979 911 SC with 10:5.1 high compression pistons and EVO 2 camshafts profile. I'm asking about heat range. The brand does't matter, I woul prefer Bosch but NGK would be ok. Please if you have recomendations and opinions, please let me know. Thanks.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 12-13-2005, 04:14 PM
abit off center
cgarr's Avatar
I am using the NGK dcpr6e 12mm plugs in a twin plug 3.2 10:5.1 dme engine, I dont think this is really that high of compression?
______________________
Craig
G2Performance
Old 12-13-2005, 04:21 PM
Do you have problems with that heat range, like detonation and flooding?
1972 911T
Old 12-13-2005, 04:43 PM
drag racing the short bus
dd74's Avatar
Is 92 the highest octane fuel Puerto Rico has? How is your engine behaving?
The Terror of Tiny Town
Old 12-13-2005, 04:46 PM
93 octane is available. The engine is totally rebuilt with brand new parts.
1972 911T
Old 12-13-2005, 06:14 PM
dd74's Avatar
I wouldn't think 93 octane and 10.5:1 compression would result in detonation. You're not lugging the car at low RPMs, are you?
Old 12-13-2005, 06:48 PM
The car is for street/strip.
1972 911T
Old 12-13-2005, 09:36 PM
Designer King
Paulporsche's Avatar
I'm using 7 range in my '80 3.2 , which is single plug, on 94 octane. The CR is somewhere between 10 and 10.5:1. No pinging in this climate.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 12-14-2005, 03:19 PM
What are the stock spark plug heat range for a stock '79 911 SC 3.0?
1972 911T
Old 12-14-2005, 03:45 PM
