				Where can I find these air filters?
			I stold this picture from an eBay auction because I've been looking for a set of these air filters.  Does anyone know where I can find these?  I had a similar set but it was slightly smaller than the K&Ns and I couldn't find a filter element that fit.  They are much lighter and less bulky than the cast aluminum K&Ns.  Any ideas?
			nobody knows where to find these?
	1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI  |
			Do you mean the whole set-up or just the filters themselves? Hank at GT racing makes that type out of fiberglass and carbon fiber but they are pricey.
			Paul
	My ignition is retarded.  |
			pmo sells a similar set up- their tops are different so water does not nail the air filters when washing or driving the car
	1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race)  |
			I'm looking for the whole setup..  There are very light, stamped metal, with springs rather than the 4 posts like the k&ns
 I've not seen those in years as I believe the maker has gone out of business. FWIW, they were not very successful since the springs didn't tension the assembly enough and the stamped steel plates weren't rigid enough to prevent air leaks past the filters. The end results were excessive piston & cylinder wear. I'd stick with the K&N's or Watershields (PMO) as they are FAR better in every respect.
	Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com  |
			They were originally made by Filtron for their foam filters. I use them with modified Amsoil foam filters. To provide a better air seal, I smear synthetic waterproof grease along the top and bottom edges of the element.
	These are much lighter than the regular K&N Rainshields, but before I found these housings, I fabricated some housings out of aluminum sheet - even lighter. Sherwood
			I haven't looked recently, but I believe GT-Racing was selling either fiberglass or carbon fiber filter housings for 911's a couple years ago, those would be the epitome of lightness!
	Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver  |
			 Nobody
			Personally I prefer the look of the ones pictured here but if Steve says "no go" then that settles it for me. I ran the R shields when I first installed the new engine and I was having problems with clogged jets.
			The PMO water-shields may be steel as they are surprisingly heavy (see my database on Thom's rennlight.com page).  The old ones on Webers I used to have were a lot lighter.
			I see some CF watershields in my future...
	"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off  |
			Hi Randy -  You're right the standard watershields are steel and really heavy for what they are.  That said, I made some CF waterhields this past fall and was quite pleased with the results.  light, stiff and now that I have a decent mold - easy to make more.  Plans for the spring are to make the bases and a simple plain top like the ones above.
			Regards, Andrew M
	1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car  |
			Are you going to sell them?  If so, I might be interested...  a few years ago there was a guy named Carbon Joe that was doing them.
			Selling them as a complete set and individually is the plan - Through our host ideally.
			AM
	I say we take off, and nuke the site from orbit. It's the only way to be sure. 2009 Cayman  |
			In the PNW we need water shields - they have skirts that come down like the eaves of a house...
			Daman (series900) sells fiberglass k&n style watershields.  I think he gets $125/pair for the tops.
