Porsche Crest MSD Ignition
Can some one give me a guide on installing an MSD box (with msd coil) on a 74 CIS 911 with pictures.
I have found the wire colors dont match on my car to what the book says they are. I ask for pictures and description for all of us people who have MSD's in their garage and dont know how to install it. Wayne Dempsey left pictures out from his book on this.
I can tear apart airplanes but when it comes to cars, they just dont make any sense to me. I could go on and on about the differences between airplanes (Jets not the carberated ones...thats another story)and cars. Someone please give us some pictures.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 12-06-2005, 04:58 PM
Do a search on "MSD Wiring".
There a plenty of posts on this subject. I just installed a twin plug system on my '73 chassis an the postings were invaluable.
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 12-06-2005, 05:55 PM
Nitrometano's Avatar
Your '74 911 have electronic ignition with pick up coil?
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 12-06-2005, 06:53 PM
DohertyCM,
The best thread for the MSD install for your car is here:
MSD wiring help needed
Hope this helps.
Rex
1975 911s
1997 Saab 900s
Old 12-06-2005, 07:13 PM
I have no idea what kind of coil I have....But it will be replaced by a MSD coil as well.
I believe the rev limiter is in the distributor if that is what you are talking about.
Chris
Old 12-06-2005, 09:13 PM
Early_S_Man's Avatar
Porsche Crest
Doherty,
Nitrometano's question was whether you have magnetic reluctor trigger with magnetic-pickup coil ... and, no, you don't, since that didn't happen until the '78 models!
Your coil is the Bosch 0.221.121.006 CDI model with closely-spaced primary connectors for the special wiring loom connector.
Something wrong with your Permatune box?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-06-2005, 10:16 PM
Nothing is wrong
Nothing is wrong I wanted to do everything I could to improve the performance of my CIS 2.7 without having to tear down the motor.....yet. I know the cams are next. But I dont want to part with the CIS system. How are those performance plug wires?
Do I really need anything else for the MSD system if I put the 6000 rev limiter on the MSD box. My rev limiter is currently set at 6300 from the distributor....or so they say.
Old 12-07-2005, 07:23 AM
Put a big bore throttle body and 1978 big runners.
1972 911T
Old 12-07-2005, 07:27 AM
Getting rid of those problematic Beru wires is a good start. You'll need to do that anyway if you go MSD since Beru wires are incompatible.
Old 12-07-2005, 09:00 AM
Yellowbird RS's Avatar
Need to up-grade the spark plugs wires I'm running megnaore Racing 100 mm. Great up-grade also run a NGK iridium plugs @ .40
X/A
Old 12-07-2005, 09:20 AM
speaking of plugs
My mechanic pulled by platinums out and put regular back in because he said that they were getting so hot that they would break and cause damage to valve. And then showed me a couple. What about the iridium plugs? And does it matter on what wires I get? how about these?
http://cgi.ebay.com/ebaymotors/Porsche-911-74-83-S-SC-Turbo-Iginition-Wires-09-385red_W0QQcmdZViewItemQQcategoryZ33692QQitemZ8020 467277QQrdZ1
also
"Put a big bore throttle body and 1978 big runners" is this a CIS system from a 78?. I had heard that the performance that was gained was not worth the expense. Care to counter that?
Old 12-07-2005, 09:52 AM
Link not working.
Old 12-07-2005, 10:49 AM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
What? Beru wires won't work with MSD?
Damn, I'm gonna have to get new wires... again... when I pony up to an MSD ignition. I suspect I'll see a good difference between the '69 battery inductive system and a nice MSD unit.
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 12-07-2005, 12:18 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Like night and day.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 12-07-2005, 12:26 PM
Nice Dhoward... I figured it would be a great difference. My '69 has a '70 2.2l T engine in it, but I'm (going to be) using the '69s ignition, as I didn't want to futz with the wiring too much. Dropping in an MSD unit should be pretty easy, right?
Matt J.
Old 12-07-2005, 12:34 PM
Angry dead link
ebay item 8020467277, sorry for the dead link.
Old 12-07-2005, 12:41 PM
dhoward's Avatar
Very easy, Makes a really fun spark! For a car with regular inductive ignition and carbs, you notice a big difference in lower RPM driveability. Makes carb adjustment easier too. May need a newer tach as the 69 had a tach interface box.....
Dan
1969 911T (sold)
2008 FXDL
Old 12-07-2005, 01:04 PM
hmm... I have a tach from a 70 T available to me. The engine is from the same 70T that had the Bosch CDI ignition. Do you think swapping the tach over would be a good idea when I get around to doing the MSD? (probably Feb-March time frame)
Matt J.
Old 12-07-2005, 02:17 PM
You'll need the MSD tach adaptor or you can have North Hollywood Speedometer convert your '71 tach to be compatible with the MSD.
Tom Butler
1973 RSR Clone
1970 911E
Old 12-07-2005, 03:28 PM
Porsche Crest
Matt,
If you use the '70 ballast unit along with the '70 tach wired to the new coil same as the factory coil ... it should work fine without having to use the MSD tach adapter, which isn't intended to be used with a tach designed for a high-Voltage signal like produced with the ballast unit. The MSD tach adapter is designed for tachs using the conventional switched 12 Volt signal at the coil.
Warren Hall, Jr.
Old 12-07-2005, 04:17 PM
