I had a constantly on left dash bulb indicator in dim mode.
Changed expensive flasher and fixed.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-25-2006, 03:35 AM
My '70 occasionally goes into the "both lights on" mode as described in earlier posts. What has fixed it every time for me was to clean the fuse holder contacts and fuse ends for the turn signals.
Paul
Old 08-25-2006, 03:40 AM
Porsche's Avatar
Both times this occurred in my 77 911, one of the indicator bulbs had burst and when replaced, the problem went away - I thought it was an intentional thing that Porsche did to tell the driver one of the indicators needed replacing. Is that right?
Erwin
'97 Boxster (sold), '67 911S (sold), '77 911 (sold)
Definitive Australian/ New Zealand Porsche Resources
Old 08-25-2006, 04:11 AM
Slumlord
Porsche_monkey's Avatar
I would never buy a new flasher without first disassembling the old one. They typically have cracked solder joints from vibration, just touch it with a soldering iron and they work again.
Bulb wattage issue: Dim Indicator Bulbs - Both Illuminated
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-25-2006, 05:02 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Since I switched to the LED lamps in the back mine has done the dim flash...I have been told to add a resistor to the circut since the LED's don't consume the power and the system thinks a buld is out.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 08-25-2006, 05:15 AM
