Nose bearing leaking, what's cure?
I changed the pulley seal last year, it is still leaking. I did a search and DavidI uses Curil-T to stop the leak. I have Curil T, but is there anything else that will work?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Is it leaking from the inside or the outside? Curil T on the inside is what most recommend (I used when building and it doesn't leak). If it's the outside, just act like it's not leaking until it becomes a waste hazzard site.
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
It is leaking from the OD of the bearing.
Irrationally exuberant
I've had some luck cleaning the area thoroughly and using JB Weld around the #8. The aluminum will be impregnated with oil to you really want to clean the area with some sort of solvent.
I'd be surprised if Curil-T (that green non hardening sealant) would work in that application. I could see it working if you used it during assembly but I doubt it would work applied to the outside. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Friend of Warren
On case leaks I have had excellent results with DOW 730 sealant. It is oil and gas resistant and remains flexible. The stuff ain't cheap. It is $74.00 a tube from Aircraft Spruce.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Re: Nose bearing leaking, what's cure?
I highly recommend it. To make it work, you must get the area very clean and let it cure over a week's time. David
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
OK,
Who wants to sell me a single use of the Dow corning 730. Send me the tube, and I'll send it back with the payment. I don't even know where to get the stuff.
Friend of Warren
DOW 730 SOLVENT RESISTANT SEALANT 3 oz. tube - P/N 09-00383 _ $82.50 A one part RTV paste which cures at room temp. to a tough rubbery white solid. it is used for bonding, sealing and caulking where resistance to fuels, oils and solvents is required. Excellent on fuel line pipe threads, repairing fuel lines and tanks, bonding components exposed to fuels, oils and solvents. temp. range -85° to 400°F. Stores refrigerated for years. DOW 730
It worked, the white DC730 did it. I spent a saturday removing stuff, spread it on, parked it for a week, and drove it. No leaks.
I'm not here.
Nuh-Uh! Just kidding...But do show us your work please...
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?) |
cycling has-been
I lived with mine for over 8 yrs, then went to the only cure left - rebuild.
good luck Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
